Wheel Vibration When Braking
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by DrPepper, Sep 5, 2017.
  1. DrPepper
    DrPepper Veteran Member
    195
    42
    Aug 29, 2017
    Central VA
    I just replaced the front shocks. New aluminum wheels & Hankook tires. Wheels & tires were balanced. New brake pads. Original hub & rotors.
    Problem is when I'm traveling over 40 mph and apply the brakes firmly, the left front tire vibrates. I can see the fender vibrate up & down. This isn't a pulsating action like the rotor is warped. It's a vibration. I've never experienced this.
    I haven't rotated the wheels yet.
    Anyone experienced something like this? Looking for ideas.
  2. 71 rs BBC
    71 rs BBC Veteran Member
    477
    65
    Nov 28, 2016
    Indy
    My 55 did it. I couldn't figure it out so I kinda blamed it on the drilled rotors. After a while it went away on its own. I'm thinking it was the pads now. I know this wasn't any help sorry. Good luck!
  3. BonzoHansen
    19,500
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    did you resurface the rotors with the new pads?
    rotate the tires and see what changes. Can you rotate front to rear?
  4. budro6968
    budro6968 Veteran Member
    3,377
    562
    Apr 2, 2016
    Jax Florida
    maybe Check the front end parts or the Shocks just installed see if something got loosened up.
  5. COPO
    18,085
    875
  6. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    106
    28
    Jul 17, 2017
    New Brunswick
    at the least you have to resurface the rotors or replace them, when installing new pads. This is where your vibration is coming from
  7. biker
    biker Veteran Member
    1,026
    118
    Dec 7, 2014
    New Liskeard Ontario Canada
    Definitely get your rotors resurfaced. Our cars have lots of meat on them for this reason and some shops still have a proper lathe to do it.
