Where are the numbers?
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by 79camaro305, Sep 13, 2001.
  1. 79camaro305
    79camaro305 Veteran Member
    1,746
    Jul 8, 2001
    Hainesport, NJ USA
    I have totaly lost my mind, and have forgoten where to look for the numbers on a V8 engine. The vin number says that the engine should be a 305, but that may not be the case. Where am I supposed to look?
    I have just gone completly blank!
    79 with 305, being completely redone inside and out (but no engine work) and a Sunroof. Why?
    81 with a v6 Dual flows, t-tops. Will be fixing body soon and maybe repainting-gonna be daily driver.
    Beautify America. Drive a Camaro.
  2. 76camaro454
    76camaro454 Veteran Member
    609
    Jul 6, 2001
    Vraa, Denmark
    Look in the front of pass.side cyl. bank - a little pad just below cyl.head , behind alternator.
    Should say something like: V 0612 TBY - not necessarily these # !!
    Also casting# on rear drivers side of block - difficult to see with engine in car.
    Brian
    1976 Camaro 454,TH400 - 3000 stall,3.23 Posi,Dual 2,5" exhaust w.Apple Racing mufflers,T-tops.
    Coming soon : Rollcage,traction bars
