Where can you get OEM style engine clamshell mounts?
Discussion in 'High Tech Retrofits' started by 76BumblBRally, Aug 9, 2010.
  1. 76BumblBRally
    76BumblBRally Veteran Member
    395
    Feb 28, 2005
    Litchfield, CT
    I am swaping in the LM7 into my car and I am using the trans dapt 4572 mounts so I can use the factory clamshells and upon inspection of my factory mounts the driver side is cracked so I will be needing at least new ones. So... where can I get a set of clamshells that will work with the factory style frame side mounts and the trans dapt 4572 mounts?
  2. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    I have a pair you can have, just pay the shipping.
  3. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    I believe GM still sells new ones. I was able to purchase some for my 77 Nova. Jonesy's deal would be much better though :)
  4. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    rockauto, auto parts store, etc. auto parts stores stock them. Make sure you get the "without HD engine" and not "with HD engine" ones
  5. drptop70ss
    drptop70ss Veteran Member
    700
    Jul 19, 1999
    NY zip 12538
    If you are talking about the steel shell that bolts to the engine it is either a dealer or used only part, not stocked at parts stores. Either weld the crack or get some from someone parting a camaro, they are not all the same between car lines.
  6. Cardinal
    8,270
    26
    Jun 22, 2003
    Endicott, NY
    Gary's-U-Pull-It. Junkyard. There must be a million of them in junkyards.
  7. 76BumblBRally
    395
    Feb 28, 2005
    Litchfield, CT
    Does anyone know if a company like energy suspension or prothane sells a OEM style zinc plated unit that would match nicely with the energy suspension frame side mounts that I already have?
  8. 76BumblBRally
    395
    Feb 28, 2005
    Litchfield, CT
    Anyone know of any aftermarket pieces?
  9. Philip
    1,807
    May 30, 2006
    Marana, AZ
    Give me a minute to check the part number and I'll tell you what other vehicle, if any, used the same engine mount bracket.
  10. Philip
    1,807
    May 30, 2006
    Marana, AZ
    332648 is the part number for the clam shell bracket that bolts to the engine. It was only used on F bodies and the number will be stamped into the side.
    Here is a photo of the one used on A,B and X body cars. It is reproduced, the part number on the new GM part is different, but the mount is the same. If you know some one in GM parts they can probably cross the original number to see if it is available under a new part number.
    Even though these brackets look to be the same as used on every GM car and truck since 1973, they are different. The way the bracket sits on the mounting tabs of the mount is not the same, the heights of the bracket from the through bolt hole to the engine mount surface are different. I have heard of guys cutting the tabs off of the mount to make the bolt fit but the tabs or ears are designed to support the engine weight, the bolt just holds it together. You have to use matching parts that are correct for your chassis to fit the engine in properly.
