Where to mount computer???
Discussion in 'High Tech Retrofits' started by OsborneConst, May 4, 2017.
  1. OsborneConst
    OsborneConst Veteran Member Lifetime Gold Member
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    Where is everyone mounting their computers? I am having a hard time finding a good spot with a full interior with all the A/C and ductwork, inner fenders, etc. I want to do a clean install. The original plan was under the hood, behind the drivers headlight, but I have switched my cold air intake to that side. I am willing to Rewire the whole thing to make it work.
  2. Zspoiler
    Zspoiler Veteran Member
    3,148
    239
    May 6, 2012
    Federal Way, Washington
    One suggestion And where I mounted my Crane HI-6TR.Is by the tranny tunnel and the passenger foot well with MSD rubber shock mounts.Even if you have to build a box to protect it.
  3. dale68z
    dale68z Veteran Member
    1,338
    18
    May 14, 2009
    Glendale Arizona
    I put mine behind the wheel well near the factory junction box, on the firewall.
  4. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    I had my DBW box there, but I removed that, and it looks like a great spot for the computer! Now, I just need to get some ideas for making/reworking my fuse block and where to mount that to.
  5. hot72rod
    2,990
    36
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I installed mine on the drivers side under the fender.
  6. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I installed mine behind the dash above the AC evaporator.
    you can see it in the upper-right part of the firewall.
