Which Bellhousing ???
Discussion in 'High Tech Retrofits' started by Shiny Red, Dec 11, 2012.
  1. Shiny Red
    Shiny Red New Member
    10
    Dec 22, 2009
    Hudson, WI
    I'm trying to mate a 04 Escalade LQ9 with a T56. The bolts in the bellhousing that came with the T56 do not match up with the rear lower bolts of the F-Body oil pan. Can a bellhousing from a 04 GTO be used to bolt up to a F-Body oil pan?
  2. camarochevy1970
    camarochevy1970 Veteran Member
    7,782
    51
    Jan 23, 2003
    Pittsburgh, PA
    no, the GTO oil pan was different, and therefore I believe the bell housing had to be different to accommodate that. Not 100% certain on that, but fairly sure
  3. camarochevy1970
    7,782
    51
    Jan 23, 2003
    Pittsburgh, PA
    a quick search makes me think the only thing different is that if you use the gto bellhousing, you have to use a gto starter.
  4. Shiny Red
    10
    Dec 22, 2009
    Hudson, WI
    Thanks for the info. I already have a starter for the LQ9, so I guess I'll be looking for a F-Body bellhousing. Anybody have one for sale?
  5. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    If you have an F-car oil pan (LS1) and an LS1 T56 bellhousing then they should match up. I'd bet you have the wrong bellhouing. Maybe an LT1 unit or something. Get the proper LS1 F-car bellhousing and it should all match up.
    ...or better yet, get a scattershield for a '98-02 Camaro/Firebird. It will match up to what you have, and contain all the shrapnel should it "give its notice" at some point.
