Which headers?
Discussion in 'High Tech Retrofits' started by tdm119, Jul 8, 2010.
  1. cubs2008
    cubs2008 Veteran Member
    245
    Jul 30, 2008
    Chicago, IL
    Ok guys I got these mounted up and YES they are low if your car is lowered but I am going with them. BTW, they are a VERY nice fit and quality....look great. I might have had more issues as my motor sits back further then a normal LS would. Let me know if you have any questions. I can take pics of the other side if you want.
  2. ErikNORCAL
    ErikNORCAL Veteran Member
    1,141
    12
    Aug 6, 2003
    now in VA
    Sweeeet! Um hello, need more pics of the car! Do you know what oil pan you have and how much below the headers are in relation to the pan? Auto or manual trans? I got these headers to hopefully fit manual clutch linkage.
  3. tdm119
    tdm119 Veteran Member
    177
    Oct 8, 2009
    Kansas City Mo.
    Yes more pics how low is it
  4. cubs2008
    245
    Jul 30, 2008
    Chicago, IL
    the oil pan is off a 2002 camaro. the headers about equal with the pan and cross member. I'll take better pics next week now that they are all bolted up. keep in mind my motor sits back further because I need the maggey sc to fit under the stock hood (just clears). So for me I had to add a 45 fitting to the oil pressure sending unit but the starter does fit in and out without taking off the headers.
    test fitting the maggy
    hood closes!
    my car sits low. 3 inch detroit speed leafs and coil overs in front
    twin disk McLeod clutch!!
  5. ErikNORCAL
    1,141
    12
    Aug 6, 2003
    now in VA
    Bo-ing!! whoa, nice ride! From the last picture, looks like the oil pan is about even with the crossmember. That should be a good reference point. I got the 1" set back plates and have heard that it puts the motor pretty close to the bulkhead and even with the crossmember for an f-body pan. I see you have a hydraulic clutch resevoir, was the car an original stick shift car? if so, does it look like the z-bar would clear the headers by looking at the original mounting brackets on the frame?
  6. cubs2008
    245
    Jul 30, 2008
    Chicago, IL
    the pan sits just higher then the crossmember, we were still fudging with it in that pic. the headers are lower then the frame. yes it was an original stick car
  7. cubs2008
    245
    Jul 30, 2008
    Chicago, IL
    oil pan clearance
    had to move oil pressure sending unit and protect wires with heat sheild
    power steering, alternator and line ran for the meth injection
    they are low!
  8. cubs2008
    245
    Jul 30, 2008
    Chicago, IL
    anyone running the edelbrock ones that is willing to take pics to compare?
  9. Sode
    Sode Member
    66
    Jan 15, 2010
    I'd be interested in the comparison as well.
  10. cubs2008
    245
    Jul 30, 2008
    Chicago, IL
    wouldn't want to change plugs often but overall very good fit!
