which lt1 accessories
Discussion in 'High Tech Retrofits' started by Camaro GT, Jun 12, 2009.
  1. Camaro GT
    Camaro GT Veteran Member
    103
    Apr 18, 2006
    Kamloops, BC.
    ok so iam building an lt1 i got for free to put in my car it doesnt have the intake so i will not be going fuel injected... i have already ordered the lt1 carb intake from gm performance and the opti spark eliminator...
    what iam wondering is can i use a gen 1 dampner and run v belts and all my old accessories with an lt1 ?
    also i know the waterpump is driven off the cam planning on keeping it that way
    i also realize that serp belts are wildly superior i just dont have the time to scroung bone yards or the cash to buy an aftermarket setup ... if i have to go serp i guess ill have to buy everything one part at a time
  2. LT1 WS6
    LT1 WS6 Veteran Member
    510
    May 25, 2009
    Sandy Springs, GA
    How do you plan to route Vbelts without a water pump pulley?
  3. Camaro GT
    103
    Apr 18, 2006
    Kamloops, BC.
    i was planning on using shorter belts and just going crank to power steering on one side then crank to alternator on the other side
    hell i suppose i could even move my alternator to the left hand side and mount it below the powersteering pump but that would be a little more work
  4. 130fe
    130fe Member
    50
    May 7, 2006
    Jacksonville, FL
    Gen 1 SBC and LT1 (gen 2) accessories (bracketry) don't interchange. Your best best would be to find a set of F-body or b-body accessories on ebay or somewhere.
