which power steering pressure hose to use
Discussion in 'High Tech Retrofits' started by Dallas camaro, Dec 9, 2015.
  1. Dallas camaro
    Dallas camaro Member
    30
    Apr 6, 2015
    Midlothian,tx
    can anyone assist me with this issue that i have run into. i tried to use the stock power pressure hose,but it would not work.any suggestions on what hose i should use?
  2. APEowner
    APEowner Veteran Member
    646
    11
    Dec 9, 2013
    Albuquerque, NM
    Umm. If we knew a little about the application we might be able to help. Car, box, pump, what the problem was with the stock hose....
  3. Twisted_Metal
    26,944
    925
    Year of the Camaro too.
    In 79 or 80 (Don't remember which) the fittings changed.
  4. Dallas camaro
    30
    Apr 6, 2015
    Midlothian,tx
    Power Steer Pressure Line
    I Have A 1981 Camaro. Im Using A Ls1 Power Steering Pump And The Gear Box Is Stock One Out Of A 81 Camaro. The Issue Im Having Is That The Hose Is Too Long.
  5. Twisted_Metal
    26,944
    925
  6. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    Fbody LS1?? Or Corvette LS1??
    I had a Camaro LS1 stock hose and pump on my 71 Camaro with a later gearbox and it fit fine. Had to tweak the hose a bit
  7. APEowner
    646
    11
    Dec 9, 2013
    Albuquerque, NM
    If that's the only issue I'd take it to local shop that does hydraulic hoses and have them shorten it.
  8. Madmike72
    Madmike72 Veteran Member
    243
    Nov 26, 2010
    Walpole Massachusetts
    I used a 2001 Silverado hose from Napa. I bent it a little here and there but it fit nicely. Definitely not too long. If it was any shorter it wouldn't have worked. I'm using a truck pump, I'm not sure if it will work as well with the Ls1 pump.
