Which Throttle Cable for LS1 Swap
Discussion in 'High Tech Retrofits' started by Protour-Camaro, Sep 17, 2012.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Agree, application is for carb And is only 24" long
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Ah.....I see my Summit link died.
    You can just Google the info "Lokar 48" LS throttle cable".
    http://www.speedwaymotors.com/search-lokar-ls-1-throttle-cable.html
    There's a cheaper option from Spectre someone else posted before though.
    It's adjustable and costs half IIRC.
  3. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Did you have you use the sold seperatly holder as well?
  4. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    Sorry I don't have exact model van I just measured the length I wanted and found one to match with the correct ends
  5. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Huh ?
  6. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    I had the same problem trying to find a cheap alternative and I found that a cable from a mid to late 90's FWD, with the 3100/3400 V6 such a a Monte Carlo or Malibu will work. It is about 32-36 inches long, has the correct end for the LS1 TB. You will need the cable backet for the TB and the firewall opening will need to be modified for the cable attachment. Good Luck.
  7. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    Thanks for the info, I just tried to scour eBay trying to find something from a late ninities 3100/3400 engine, maybe a grand am or malibu and no luck
    Maybe someone can figure out a part number and everyone will be able to take advantage of it
    If all else I'll get a lokar cable and trim it to fit....just hate to spend $60-75 + shipping for one if I can get a oem cable from a least popular car for $16-30 that will work
  8. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    Accelerator Control Cable GM part # 15153422
    Fits 1998-2005 Chevy Astro
    GMpartsdirect $26.38
    ^ Maybe this is it???
  9. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    I think he means the billet bracket, I am finding that all of the lokar universal cables looks like they have to be used with this bracket
    Is that the case or can you use the lokar cable with the stock throttle body bracket?
  10. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    22619740 < This fits 2000-2003 Malibu 3.1 V6
    22615285 < This fits 1997-1998 Malibu 3.1 V6
    The site I got this from didn't show a part number for 1999?
    Maybe it's the second number? 1997-1998
