Which Throttle Cable for LS1 Swap
Discussion in 'High Tech Retrofits' started by Protour-Camaro, Sep 17, 2012.
  1. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    Just want to point out I bought one of those eBay Lokar steel braided cables...I got the 36" trim to fit cable so it would be long enough
    I haven't mounted it yet, but it does have the correct ends for our cars so other than trimming it's a bolt in deal to the stock TB bracket. Just use larger washers where it comes through the firewall.
    I paid like $59 shipped...I was dreading spending the money, but I am glad I did now :bowtie:
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Yup, I bought the black 36" Lokar cable. Its too long for sure, could use a few inches cut off.
    I went to Lowes and got large diameter washers with 5/16" holes and works perfect. I think I'm going to epoxy them down so they don't move.
  3. my73Fcarproject
    my73Fcarproject Member
    81
    Aug 7, 2012
    phoenix, az
    The number for the late 90's m/carlo is 12554160
  4. andrew69_04
    andrew69_04 Veteran Member
    254
    Jan 8, 2012
    Berthoud CO
    the 98-02 f-body cable's are the same. There are 2 different cables used from the factory. The cable that will work with your swap is the cable for a non TCS/ASR car. The other cable is designed to work with a traction control motor and will not fit the throttle body.
    If you get one new from the dealership, I believe they are ~$16
