Which throttle & TV cables for TPI w/ TH350 in '79 Camaro?
Discussion in 'High Tech Retrofits' started by Penix, Apr 30, 2010.
  1. Penix
    Penix Veteran Member
    1,830
    May 28, 2001
    Concord, CA, United States
    Finally following through with installing TPI on my car, but I've hit a snag, I can't figure out which throttle cable and TV cable I need to use. Knuckle Dragger mentioned a throttle cable from an S10 but couldn't remember the specifics, and nobody seems to know which TV cable to use. Anyone able to clue me in here?
    Thanks!
    - Joel
  2. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    You can try giving bowtieoverdrives.com a shout and see what they tell you.
  3. Penix
    1,830
    May 28, 2001
    They know overdrives, I doubt they'd know which TV cable to use with a TH350.
  4. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    I made it simple when I did the TPI in my Corvette, I used a TV cable from a TPI equipped 700r4 tranny...I bought it new from TPI parts I think..it's been a while. But I had a 700r4 tranny and I know yours is different.
    And I picked up a universal throttle cable kit from spectre and trimmed it to fit my corvette firewall and cable bracket on the plenum...it worked perfectly. Cost me around $15-18 shipped on eBay.
  5. Penix
    1,830
    May 28, 2001
    Wait a minute, the 700R4 TV cable doesn't work on TH350's does it?
    That universal throttle cable looks fairly decent, but I'm really anal about the throttle and TV cables look'n similar hahaha Now, if they make a universal TH350 TV cable to match... ;) hahaha
  6. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    It shouldn't work, that's why mine was an easier job...not sure how yours can be accomplished.
  7. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    700r4 cable will not work. It's diameter at the transmission is too large.
    Maybe a cable for a truck or Camaro with a straight 6?
  8. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    Get the Lokar 24 inch cable. (did some searching on here and thats what everyone has used, or a late 80's S-10 V6 throttle cable)
    Get the Lokar TH350 TV cable.
    Get the Lokar throttle / TV bracket that bolts to the plenum.
    Easy money. Im doing the same swap, same car, those are the parts ive got.
