Which to keep: headers or steering?
Discussion in 'High Tech Retrofits' started by daniel76309, Jan 21, 2011.
  1. daniel76309
    daniel76309 Veteran Member Lifetime Gold Member
    935
    Oct 22, 2005
    Niceville, Florida
    I encountered an unexpected dilemma with the LS3 transplant and was wondering if anyone has any ideas that might help: I have a rack and pinion, and the steering shaft needs to go where the #3 header tube is. So, I can have either an exhaust system or steer, but not both.
    Potential solutions:
    1. Currently there is a u-joint at either end of the steering shaft. I could install a third u-joint and a support bearing so that the shaft can go around the header. The problem is that the u-joint angles woudl be approaching the max allowable, and it seems a little "iffy" to me.
    2. I would feel better about the steering if I could keep one solid steering shaft, but that would mean modifying the headers. I HATE the idea of cutting them up however. They are brand new Dynatech's, and have a beautiful ceramic coating. AND...the deal breaker (I think) is that in order to insert bends to detour the steering shaft, I would have to cut the header tube down where all the tubes come together ahead of the collector, and it would therefore be impossible to circumfrentially weld the new section of tubing in . I was wondering if there is a "band clamp" like this: http://www.jegs.com/i/JEGS-Performance-Products/555/30730/10002/-1?parentProductId=753274 that could be used to join header tubing (1 7/8") without welding? I did an internet search but the smallest size I could find was 2".
    Any other ideas?
    Some pictures to illustrate:
  2. daniel76309
    935
    Oct 22, 2005
    Niceville, Florida
    (Edited: Photos added)
  3. 70 gsconvt
    70 gsconvt Veteran Member
    1,095
    Sep 30, 2009
    Wadsworth, OH
    Looks to me like your best option is to put another joint in the steering. Just make sure it's very secure to avoid slop.
  4. K5JMP
    10,216
    9
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    contact Jakeshoe... he did this same mod for a customer about 2 yrs ago..
    he can get ya squared away...
    as I recall he sectioned the header tube to make it work...
  5. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    we had same issue on baja truck we put a solid hym joint at the corner and then put 2 little shafts in with u joints on each end we used http://www.borgeson.com/ shafts
  6. dcart1
    dcart1 Veteran Member
    407
    Jan 22, 2009
    springfield,ohio
    Somewhere I saw one that they had to loop that header pipe out farther, then back in.
  7. daniel76309
    935
    Oct 22, 2005
    Niceville, Florida
    Thanks for the replies.
    This morning I mocked it up using 3/4" wooden dowel, 3 u-Joints, and a support bearing in the middle. There is very little "wiggle room"--the shaft and support bearing have be in just the right place, VERY close to the header, or it binds. I am building a little adjustability into the bracket that holds the support bearing and I may need to ding the header in slightly, but I think it is going to work out ok.
  8. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    I have 3 u joints in mine also. The shaft basicly goes straight up against the frame till the last minute.
  9. greencamaro1981
    604
    Jun 2, 2010
    Montana
    looks good 383 but one question is ur support greasable or rebuild-able or do you just need to replace once in a while the one i made has a grease zerk on the top so it wouldn't get sticky
  10. 383Camaro79
    806
    Feb 11, 2000
    Alton, IL, U.S.
    no its not greasable. Just a plastic bushing in mine.
