Which VA system with LS?
Discussion in 'High Tech Retrofits' started by badazz81z28, Mar 25, 2016.
  1. badazz81z28
    17,143
    555
    Las Vegas, NV
    Seems the VA kits are set-up for the SBC brackets, what kit do I buy for an LS engine?
  2. paintman65
    paintman65 Veteran Member
    181
    9
    Jan 8, 2012
    Brenham TX
    Vintage Air sells a front runner setup for the LS that is nice and compact. Holley also has factory looking brackets.
  3. badazz81z28
    17,143
    555
    Las Vegas, NV
    Which VA kit do you buy? Part number is what in looking for as the 70-81 kits come with SBC brackets
  4. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    I had to ask for an "upgrade" from the VA dealer. They basically swapped brackets for the correct ones and shipped it with LS kwik performance AC bracket. Cost an extra $150 over the sbc price.
    They didn't have it listed, I had to ask for it over the phone when talking with the salesperson.
  5. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I did the same thing Dennis did and called them to order what I needed based on what I was running and the fact I was using the Holley accessory drive kit. That also changed the AC hose fittings to some degree, so you might ask them to swap out the OEM install hose fittings with some that work properly.
  6. gray86hatch
    gray86hatch Member
    74
    May 31, 2012
    battle creek mi
    I bought the unassembled hose kit so I could make them the way I wanted
    Also didn't buy the kit so I didn't get any brackets just picked the parts alacart.
    Evap kit
    Condensor kit
    Compressor for the holley bracket
    Unassembled hoses.
    Only thing I have to buy is the triniary switch
    Tim
  7. badazz81z28
    17,143
    555
    Las Vegas, NV
    I think I want to use the Holley brackets to keep the ZoEM match
  8. 71RS/SS396
    71RS/SS396 Veteran Member
    2,627
    31
    Aug 26, 2008
    Wake Forest NC
    I used the EZ-Clip hose to do the lines, it's more expensive, but it's smaller in diameter , more flexible and will bend a tighter radius, and you can install the fittings yourself. The fittings can also be disassembled later if need be, you'll just need to replace the clips which are only a few bucks.
  9. paintman65
    181
    9
    Jan 8, 2012
    Brenham TX
    The VA part numbers are:
    Bright finish
    174014 with power steering with pump
    174016 with power steering without pump
    175015 no power steering
    Black hardcoat finish
    174011
    174017
    175011
    This setup includes compressor, water pump, alternator and a lot of other parts.
  10. Goodwrench1965
    Goodwrench1965 Veteran Member
    925
    41
    Apr 23, 2010
    Charlotte NC
    I guess you will be using electric fans since your installing LS engine. Certain compressor type works better with electric fans and the other type works best with mech. Fan. Ask dealer and or VA about that. Also review which side of engine compressor mounts on with the brackets you choose. The standard VA brackets for SBC from VA mount compressor on drivers side like Chevy did. I prefer compressor on passenger side so hoses don't cross over engine. If you change brackets to relocate compressor make them change the hard lines from the condesor to match.
