Which year 4l60e's are compatible?
Discussion in 'High Tech Retrofits' started by algershick, Oct 3, 2010.
  1. algershick
    algershick New Member
    Sep 29, 2010
    Killeen, TX
    I've had a 5.3L for about a year that I planned on running in my Third gen with a T56. I think I'm now leaning more toward dropping it into my '79 with an automatic.
    I haven't researched this at all since before I was planning on running a manual. What year 4l60e's am I looking for to be compatible with a Gen III motor and wiring? I'm not running a carb or anything. Will the older LT1 era transmissions work just as well as the ones that came with a Gen III motor?
  2. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I was under the impression that the LSx and LTx engines had a different bolt
    pattern, but I was told on this forum the early ones can be made to bolt up.
    Tom
  3. drptop70ss
    drptop70ss Veteran Member
    700
    Jul 19, 1999
    NY zip 12538
    bolt pattern is not the issue, the electronics are..early transmissions will bolt up minus one bellhousing bolt. I am sure it will all depend on what trans programming you have in your PCM that you use. I would check out LS1tech for more info.
  4. omarcamaro
    omarcamaro Member
    48
    Jun 9, 2010
    clifton nj
    your better off with 700r4 no electronics. a 4l60e is basicly a 700r4 with electronics
