White/charcoal combos
Discussion in 'Body Restoration' started by TX79Z28, Jan 22, 2014.
  1. TX79Z28
    TX79Z28 Veteran Member Lifetime Gold Member
    1,136
    May 3, 2007
    San Antonio, TX
    I believe I have FINALLY decided on the color for my 79. The body shell is in the last stages of block sanding, so I want to finalize things in my mind, but need some ideas.
    I know for a fact I want to paint it white (probably '08 I believe? Corvette white), black interior, and silver/charcoal stripes/decals. My only question is regarding the wheels. I have toyed with charcoal to more or less match the stripes, or black.
    Can anyone with a white car (late 2nd gen in particular) post pictures of their car with a good shot of the wheels?
    Also, in your opinion what color code is the BRIGHTEST white out there? something that really pops? (no metallic or candy, HAS to be solid)
  2. CDesperado
    3,590
    79
    Oct 1, 2004
    Dallas Texas
    Something like this looks really good.
    [​IMG][/IMG]
  3. TX79Z28
    1,136
    May 3, 2007
    San Antonio, TX
    Hi CD, well that's funny, that's actually the car that inspired my idea! I just want to see them with black and maybe even silver wheels. The rest of the car is fairly locked in my head (for now!)
  4. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    white rims or gray ? i'd go either way ..
  5. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    Grey or black wheels would look good on white with charcoal graphics....it helps break up with white a bit.
    If you did white wheels it may be too much and hard to keep clean either way.
    I would pick a close color to the graphics and run with it
  6. TX79Z28
    1,136
    May 3, 2007
    San Antonio, TX
    That's where I am leaning towards, close match to the graphics. Just hoping to see some other examples...I imagine there is quite a few white cars out there....I even thought chrome..but that may "wash out" too much with the white
  7. CDesperado
    3,590
    79
    Oct 1, 2004
    Dallas Texas
    Personally, I like charcoal/silver better than black rims on white cars. If you have a chrome trim ring, that would work, but otherwise there isnt enough to break up the color between the wheel and the tire. Looks like the car is floating on a solid black disc.
  8. TX79Z28
    1,136
    May 3, 2007
    San Antonio, TX
    You have no idea (well, maybe you do!) what a roller-coaster this has been just deciding what color to paint this car! which is weird, because every new car I have purchased I already knew what I wanted, or picked a color within minutes! I have made a full circle and ended up with white....after looking and sampling probably 10 colors! I am torn between GM code 10 Artic Blue (C5 vette) or the pure white BC from SPI
  9. earnhardtgm3
    earnhardtgm3 Veteran Member
    3,149
    39
    Dec 18, 2007
    Camaro Country,GA
    That's my car....:) The color is 2011 Corvette White.All the exterior trim has been blacked out.Thanks CDesperado................
    Wheel Pic...I used an 80-81 fuel door emblem to match the paint for the wheels.
  10. TX79Z28
    1,136
    May 3, 2007
    San Antonio, TX
    maybe I'm getting cars confused, I could swear that I saw it was a 2008 corvette white... are they the same color both years?
