Who has installed Vintage Air?
Discussion in '1970 - 1973 Specific' started by gpm6367, Aug 10, 2019.
  1. gpm6367
    905
    46
    Feb 12, 2005
    New Joisey
    How is the dash controller secured to the dash? I saw 2 Phillips screws that look like they go through control panel but actually held lower dash to upper section.
    Looking at it from the back it had 4 small nuts on studs and I removed them didn’t budge. I don’t see any other mounting hardware and hope the dash isn’t modified for that controller.
    I found Installation instructions on line and there is no drawing and contains one sentence “ install dash control assembly” or the like... don’t want to break it...
  2. grzewnicki
    3,262
    101
    Dec 9, 2009
    Gordon from Jacksonville Fl
    OK, just crawled under the dash, from what I can see there are two points at the top where it fits into the opening (maybe slots), then at the bottom I can see two screws that screw through a plate into two spots on the stock dash to secure it. Hope this helps.
    gpm6367 likes this.
  3. gpm6367
    905
    46
    Feb 12, 2005
    New Joisey
    Ok thanks I’ll take another look at it.
  4. grzewnicki
    3,262
    101
    Dec 9, 2009
    gpm6367 and cisco 1 like this.
  5. cisco 1
    cisco 1 Member
    30
    9
    Apr 14, 2019
    quebec,canada
    gpm6367 likes this.
  6. gpm6367
    905
    46
    Feb 12, 2005
    New Joisey
    Buy mine for a quarter of the price.
  7. gpm6367
    905
    46
    Feb 12, 2005
    New Joisey
    1D3367F4-9EDA-474A-82F6-A4DED572F0AD.jpeg 76D9E8B0-A46A-4786-BD7F-4D424CAD3FCA.jpeg 37919916-F4C0-482C-B7BC-7EC71C99DD04.jpeg
    I removed the blower motor block off plate. Is there any other modification to that area? Do I just bolt the heater box to the wall and the blower motor to the box?
    Do I need to use that dum dum to seal it?
  8. 70 SS/L78
    2,697
    96
    May 5, 2005
    Rockford, MN
    I don't see any modifications. So yes just bolt on the box and blower motor. The factory did use a caulk type seal
    gpm6367 likes this.
  9. gpm6367
    905
    46
    Feb 12, 2005
    New Joisey
    Where do you get the caulk seal?
  10. grzewnicki
    3,262
    101
    Dec 9, 2009
    You can use 3M Strip Caulk or a search for rolls of butyl sealing tape.
    gpm6367 likes this.
