who is using EFI
Discussion in 'High Tech Retrofits' started by 72406, Feb 18, 2013.
  1. Kricka
    Kricka Veteran Member Lifetime Gold Member
    419
    Sep 26, 2002
    Skellefte. SWEDEN
    Holley Commander 950 TBI. Works very well, but i whish i had a intake with eight injectors instead.
  2. Fbird
    3,942
    615
    Feb 12, 2011
    atlanta, ga
    I can understand that. I refused to go TBI just because if I'm gonna do all this "stuff".....damnit it's gonna have an injector in each hole !!!!
    I had to make my intake as NOBODY did this on PONTIACS back in 2008....when I startd....
    Don't let 77Nomad preach TOOOOOOOmuch about that MS3......he's an ELECTRICAL ENGINEER!!!!! (cheater) ...lol :)
    He can build that about as easy as I can figure out the pitch diameter of a screw. (ps hey nomad you do your intake yet? )
  3. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    Cams with a lot of overlap will not give you an accurate o2 reading at idle and low rpm...it will read lean even when it is not. I am going open loop idle just to make sure that is not a problem with mine.
  4. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    Drivability is much better with port injection, too. TBI is wet flow and causes issues when you let off the gas to shift and get back in it. This has been very hard to tune out with my truck, and it's still not perfect yet.
  5. 77nomad
    77nomad Veteran Member
    2,123
    Nov 20, 2009
    Ski Town
    I'm not an engineer YET!. Still in college. BUT work has taken so much time in the last year and a half school is on the back burner. I actually took the intake to a local machinist to see about welding my bungs in. The welder had the day off. I was with a buddy dropping off a LS oil pan to get welded. So I figured I'd ask. But still no closer. I did machine a bar that will simulate a fuel rail to keep the bungs in line while welding.
    PS I found that firewall piece. PM me where you want measurements from. I stuck it up in the coat closet until I get them for you.
  6. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
  7. 7975camaro
    7975camaro Veteran Member
    219
    Mar 20, 2011
    Illinois
    an LSX ;)
  8. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    I'm not sure if its still being made, but there is an intake manifold made specifically for the SBC thats almost a direct copy of the LT1 manifold. It was called the "miniram". Made by TPIS as I recall.
  9. 77nomad
    2,123
    Nov 20, 2009
    Ski Town
    No there not still made.They get about 800 on ebay. I have a stealth ram which is the same just longer runners.
  10. PolarBear
    1,189
    Apr 24, 2008
    NJ
    TPIS still shows the miniram as available on their website
