Who is using what for a headlight relay kit?? (brighter headlights) H4
Discussion in 'Electrical Systems' started by QUAKE_WARS, Aug 8, 2019.
  1. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,021
    149
    Dec 19, 2008
    Best brand? Ebay? Classic industries? Dont want a cheap budget kit.
    Quality brand.
  2. Twisted_Metal
    27,154
    1,046
    QUAKE_WARS likes this.
  3. Twisted_Metal
    27,154
    1,046
    Here's the diagram I designed a four-relay system.
    If a relay fails... You can disconnect the factory plug from the relay and plug it directly into the lamp.
    The single power lead can be hidden in the factory loom running across the radiator support.
    This is what it looked like when assembled.
    The relays are "velcro"ed to the inside of the fenders near each headlight so the whole package is pretty much invisible.
    QUAKE_WARS and 71RSLS like this.
  4. COPO
    18,056
    862
  5. Zspoiler
    Zspoiler Veteran Member
    3,310
    273
    May 6, 2012
    Federal Way, Washington
    I just use my stock wiring on both my 1979 Z-28 and 1981 El Camino SS with H-4 headlights
  6. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    The relays make the lights brighter due to full power to the headlight itself. I tried that once with my 70 and did not like the outcome.
  7. dave@ztech
    3,510
    718
    Mar 27, 2016
    NY
    MAD electric has a kit, you might want to look at
  8. junkyardZ28find
    790
    8
    Mar 4, 2012
    des moines, iowa
    That stock headlight switch has a voltage limiting ballast inside of it and it won’t like trying to block even more power when those H4s try to pull it. I would hate to see a dash panel catch fire as a result.
    dave@ztech likes this.
  9. Jeep43
    Jeep43 Veteran Member
    1,327
    53
    Mar 30, 1999
    Connecticut
    I bought an ebay harness. I hooked one up and kept the old wiring to the other light. I didn't see a difference.
  10. COPO
    18,056
    862
    You need to connect them both for it to properly work.
