Who is using what for a headlight relay kit?? (brighter headlights) H4
Discussion in 'Electrical Systems' started by QUAKE_WARS, Aug 8, 2019.
  1. COPO
    18,065
    870
    The fuse will pop before it gets too hot.
  2. junkyardZ28find
    790
    8
    Mar 4, 2012
    des moines, iowa
    Not always the case-a slow, parasitic voltage loss and amperage gain can increase the amount of heat until it melts. Once the thermal runaway process starts, that fuse may not pop because the current isnt reaching (ie being used) the headlights because of the switch. To a lesser extent that is also the reason why fusible links protect better than just a fuse on individual circuit runs.
  3. Jeep43
    Jeep43 Veteran Member
    1,328
    53
    Mar 30, 1999
    Connecticut
    My setup had separate relays with hot and ground splitting in parallel to the relays.
  4. COPO
    18,065
    870
    Rene Melten likes this.
