Who's happy with their TKO 600?
Discussion in 'High Tech Retrofits' started by AlbertaZ28, May 26, 2013.
  1. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I dont mind the noise to be honest, it works really well otherwise.
    Tom
  2. 73 L92
    73 L92 Veteran Member
    126
    Apr 4, 2012
    Carlos, MN
    I have a tko 600 in my 73. Not loud. A little notchy on the shifts.
    They make an upgrade kit for the TKO with Kevlar lined syncros. They are supposed to offer more control at the higher RPMs.
  3. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    My TKO 600 with 0.64 OD is very quiet. A little temperamental on the 2-3 shift under hard acceleration, but otherwise fine. Mine probably has maybe 1k miles on it. My trans is one of earlier TKO's. Mine came from CC5S (before they became Hurst Driveline Conversions...). EDIT: I did the full break-in as described earlier in this thread.
    Those youtube video's are crazy. That sounds almost as bad as the g-force T5 that my buddy has in his Mustang.
  4. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    Took the Nova out for a drive today specifically to listen for any gear noise. It is really quiet, when I get the camera battery charged I'll take and post a video.
    What type of gear oil did you use?
  5. John Wright
    14,701
    212
    Aug 9, 2002
    Rustburg, Va
    Maybe the gear oil is too thin? Wonder if mixing in some slick'um kind of (Lucas) additive would help quiet things down without hurting the transmission?
    LOL...nevermind me...I'm just thinking outloud.
  6. Philip
    1,807
    May 30, 2006
    Marana, AZ
    I used GM Syncromesh oil. Think I will buy some more and change it. Tremec says it is a fill for life but the heat it sees here plus a little bit of drag racing done recently is probably breaking down the oil.
  7. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I forget what I put in it. I wonder if you guys are confusing the engine noise
    in with the trans. Bare in mind the engine is a 1963 Studebaker V8, the have
    solid lifters and angle cut gear to gear timing. The engine has gear whine as
    well as the noise you hear from the trans.
    Tom
  8. AlbertaZ28
    AlbertaZ28 Veteran Member
    258
    Aug 17, 2010
    Fort Mcmurray, Alberta
    I also used GM Synchromesh and followed the break in procedure. Speaking to the dealer he said they have had a few noisy ones come back.
  9. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Might as well get a better trans if that is the case (Magnum). You shouldnt have to upgrade a $2250 trans to be able to shift it. Its made to handle 600ftlbs of torque, how did Tremec think we were going to drive it? :rolleyes:
    I'm using GM synchromesh too, I have changed it once already at about 1500 miles. They do quite down as you get miles on it. But the noise in the video sounds like a problem.
  10. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I have had several people listen to it, including one person that has the same
    trans in his race 68 Camaro. He said it sounds like his. They are noisy, period.
    Tom
