whos sucessfully done an ls swap?
Discussion in 'High Tech Retrofits' started by 72BIGBLOCK, Aug 25, 2015.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,376
    83
    Feb 2, 2008
    SF
    :bowtie:
    who here has actually done an ls swap?
    my brothers 2000 trans am ws6 was hit beyond repair and now i have the car , he said i could have the motor and trans but i dont even know where to start with this thing. by the way its going in my 69 camaro
    i feel like something good happened but to the wrong person haha because im lost :confused:
  2. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
  3. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    Camaros.net or camaro.net is team camaro. They swap a few LS's in 1st gens over there.
  4. pajeff02
    pajeff02 Veteran Member
    118
    Aug 16, 2015
    Mansfield, PA
    Biggest thing with the LS swap is to either source the engine and trans with a complete wire harness and PCM, or purchase the aftermarket equivalents. You will need to modify the fuel system (provided you are not switching over to a carb setup) to feed the engine at 58 p.s.i. A good wiring diagram for the LS is a must. If you need any wiring info just let me know and we can sort stuff out. Make sure to retain the OBDII port for future diagnostics if anything ever goes amiss and for tuning.
  5. badazz81z28
    16,738
    469
    Las Vegas, NV
    Tons of us...very easy swap if you have the stuff you need ;)
  6. AllensaurusRex
    AllensaurusRex Veteran Member
    538
    32
    May 22, 2013
    Murfreesboro TN
    I wouldn't say "very easy"...but it is definitely easier than it was 10 years ago
  7. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    723
    33
    Aug 18, 2011
    Upstate New York
    ls1tech.com
  8. BonzoHansen
    19,398
    775
    Jun 1, 2005
    Scott from Hamilton, NJ
  9. badazz81z28
    16,738
    469
    Las Vegas, NV
    Well, I must say much more difficult if you do it the old fashioned way....
    However, they sell everything to do the swap! Buy off the shelf parts (parts specifically for your car and proven by others)
    Engine: Bolt-in is no different than a SBC using the adapter plates.
    Harness: Buy a PSI harness, connect it, a few grounds, a power source, and done
    Fuel: Buy an FI tank, plumb it, power, done
    What's hard about it? Time consuming yes, but not hard. The only difficult thing I could see is if you were taking a stock harness and trying to re-wire it yourself.
  10. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    While there's tons of information on the web, I found it handy to have some paper reference when I was doing mine. simply because these books are organized by chapters and each area of the swap (mounts, engine, transmission, and so forth). It made it easy to understand all of the components involved without it being overwhelming.
    There's several LS swap books out there, that got me started and I asked questions from there
    http://www.amazon.com/LS-Swaps-Engines-Anything-Performance/dp/1613250932/ref=pd_bxgy_14_img_z
    http://www.amazon.com/GM-LS-Series-Engines-Complete-Motorbooks/dp/0760336091/ref=pd_bxgy_14_img_y
    http://www.amazon.com/Swap-Engines-...UTF8&qid=1440708845&sr=8-12&keywords=LS1+swap
