Why do 383 stroker's cost so much?
Discussion in 'Engine Topic' started by Noah_Seward, Dec 24, 2011.
  1. Noah_Seward
    Noah_Seward Veteran Member
    291
    Dec 9, 2011
    What is it about a 383 that puts them in the 2000$ range all day long? You can pick up bbc's and 350's for alot less exspensive. Is it just that people think they are worth that kinda money? Or do they actually sell?
  2. REALZ22equipped
    REALZ22equipped Veteran Member
    123
    Aug 19, 2010
    hicksville,oh
    gm never actually produced a 383 from the factory so essentially a 383 is a custom build, requiring machining work etc
  3. Noah_Seward
    291
    Dec 9, 2011
    A 383 is actually a 350 sbc .30 over isn't it? Also aren't 383's actually a factory mopar engine?
  4. rockheadrocks
    rockheadrocks Veteran Member
    The 383 small block Chevy is a .030 over 350 with a 3.75" stroke crank. The factory 350 crank was 3.48". 383 Mopar is a completely different animal, and are really a dime a dozen compared to 440s.
  5. AJ_72
    AJ_72 Veteran Member
    5,122
    Jul 3, 2003
    Chebanse, IL USA
    A 383 is normally a 350 block bored .030" over, then the crank is changed from a 3.48" stroke to one with a 3.75" stroke.
    GM does make a crate motor that is a 4.00" bore (no overbore) with a 3.80" stroke they call an HT383 made for truck applications.
  6. 79sportcoupe
    79sportcoupe Member
    60
    Nov 22, 2011
    TN
    I was under the impression they cost 3 or 4k? I wish I could find one for 2k! haha or were you talking about used motors?
  7. Noah_Seward
    291
    Dec 9, 2011
    Yep, looking on Craigslist all day long you can find them in the 1500-3000 range used.
  8. Damon
    Damon Veteran Member
    12,875
    10
    Nov 16, 2000
    Philly area
    Factory blocks almost always require clearancing to fit that long a stroke inside them. That takes time and can't be done by a machine. Best comment from above: "because they are a custom build." Try one yourself from a junkyard block and you'll see how true that is.
  9. Led Zep
    Led Zep Veteran Member
    499
    Mar 13, 2008
    Ky
    383 is a modification.If you bore a 350 say 30 over,you need to buy new pistons regardless.Back in the day getting a 350 iron crank reground at the machine shop was 100 bucks.Now you can buy a steel 383 crank(Scat,Eagle.etc.) for 200 bucks.You can get a good set of rods for under 200 bucks.New flexplate and balancer another 150 bucks.
    When you rebuild a 350,the 383 is a good bang for buck project.
