Why exactly won't these heads fit?
Discussion in 'Engine Topic' started by joel.hunter, Oct 15, 2016.
  1. joel.hunter
    joel.hunter Veteran Member
    296
    Nov 18, 2015
    Nanaimo, BC, Canada
    These seem to be a pretty popular head on Summit and I can see why - good spec'd, aluminum heads at $895 (or $1400 Canadian to my door :( ) for the pair. However, it says they only fit SBCs up to 1986 when the changed over the rear main design. I don't understand, though, why it wouldn't fit my '89 (648 cast.) block? Has it got to do with the studs? I presume I could just switch the stud style if so..
    Thanks for any help.
    PS if anyone has a good head recommendation for under $8-900 (USD) I'd love to hear it.
    https://www.summitracing.com/int/parts/mll-h8002k/overview/
  2. azkeebler
    azkeebler Veteran Member
    584
    Dec 14, 2011
    Manteca, ca.
    Im pretty certain the only reason they say this, is due to the different intake on 86 and up. These should bolt up fine to your block as long as your intake matches the heads chosen
    Kamikaze likes this.
  3. hoppin5478
    581
    98
    Jul 20, 2015
    Tucson, AZ
    I'm fairly certain they list them like that because GM changed the angle of the intake bolts in 87. The heads will physically work but when you go to bolt up the intake it'll all line up but the bolts go in at the wrong angle. Some people elongate the intake manifold bolt holes to make the manifold work but its best to use the right manifold. When GM made this change they also switched over to center bolt valve covers. I believe those are the issues you would run in to. Someone else may be able to answer the stud question, I'm not sure there but think they will work.
  4. joel.hunter
    296
    Nov 18, 2015
    Nanaimo, BC, Canada
    Oh ok my intake is drilled for both anyway. Probably get an aftermarket one at some point, too. Awesome, thanks! :)
  5. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    The others are correct that it will fit your 89 blockm the difference is the bolt pattern of the intake.
    87 and later used different angles of the two center intake bolts on both sides. If you are using and early factory or aftermarket intake with the standard intake bolt pattern you will be fine.
    Just make sure your manifold ports line up with the head ports properly and you should have a great combination!
  6. John Wright
    14,663
    202
    Aug 9, 2002
    Rustburg, Va
    I used older style heads on my 89 TPI. I had my father-in-law spot face the center bolt holes so my TPI intake would bolt down on those heads.
