Widest Wheels
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Strange81Z, Nov 4, 2019.
  1. Strange81Z
    Strange81Z Veteran Member Lifetime Gold Member
    5,955
    16
    Nov 29, 2001
    Amarillo, Tx
    You can fit under these cars. Even if I have to do a mini tub. What’s the widest we can fit?
  2. dave@ztech
    3,479
    714
    Mar 27, 2016
    NY
    Opinions vary 315 with tubs maybe 335
  3. Strange81Z
    5,955
    16
    Nov 29, 2001
    Amarillo, Tx
    How hard is it to minitub? You have have to cut the axle?
  4. 81Z28LS
    81Z28LS New Member
    12
    Dec 16, 2018
  5. dave@ztech
    3,479
    714
    Mar 27, 2016
    NY
    In regarding to, how hard to mini tub, go to DSE's site, find the year of your car ,for there mini tub and read the install instructions, I believe some members have said around 30-40 hours? However read the install instructions, and watch the video's
  6. badazz81z28
    16,949
    506
    Las Vegas, NV
    7EC9449E-2363-4DF0-81CB-9DF17BEF59B0.jpeg E15D0BD0-1086-48D3-B225-F7921A65779E.jpeg Textbook wheel is a 335 with a mini-tubbed sec gen. You could probably squeeze a 345 in there. I run a 18x12 with 5.5” BS on a 56.250” flange to flange rearend
    it’s a time consuming job starting with a “together” car. A lot of cutting, fitting and welding. Removing all the seam sealer is time consuming!
    Strange81Z and dave@ztech like this.
  7. dcozzi
    dcozzi Veteran Member
    3,104
    426
    May 1, 2002
    Phoenix, AZ
    Mini rubbed, 335mm tire is possible by adding a 3 inch strip of metal to the center of the wheel well and cutting 3 inch into car and moving the whole stock fender well inward until you are pretty much at the frame rail. Mine was down that way and it did not require a kit. It did require a heck of a lot of work though. Nothing I was prepared to undertake. I had someone else do it. All the undercoating & stuff is definitely a big pain in the butt on these cars. There is tons of it.
    Then there was narrowing the rear seat back, moving the hooks and narrowing the bottom cushions. I did all that myself and it took time.
    camaro71/holland likes this.
  8. camaro71/holland
    1,237
    86
    Aug 27, 2003
    The Netherlands
    Saved to my favourites:
    dcozzi likes this.
  9. badazz81z28
    16,949
    506
    Las Vegas, NV
    The hours it takes to to that ^^ is probably the reason people now sell tub kits. It works, but I think that’s even more time consuming then fitting a pre fabricated set.
  10. Fbird
    4,051
    657
    Feb 12, 2011
    atlanta, ga
    it is.... because NOW you must save everything you cut out...cause it's going back in. MUCH easier to to have a prefab HALF that already fits.... MUCH easier. Still takes a good amount of work. Certainly MY first one took way more than 30 hrs ...on the tubs and fab work (we didn't have fab kits 30 yrs ago..) after my 3-4 one yeah i could probably make a little time on it at 30 hrs. Like anything else once you do 1 ... you kinda know what your looking AT and what NOT to do on the next one! ;)
    dcozzi and Strange81Z like this.
