window trim clip mounting
Discussion in 'Body Restoration' started by dutch73camaro, Nov 5, 2017.
  1. dutch73camaro
    dutch73camaro Veteran Member
    162
    34
    Jan 7, 2016
    Beverwijk, Netherlands
    on my 73 project i'm replacing the quarters, and on the new amd one's there are not the pins for the trim clips. how do you guys fix that ? pop rivets or screws ? i'm looking for the best solution. car needs to be painted yet.
  2. Green hornet
    Green hornet Veteran Member
    1,670
    276
    Oct 11, 2015
    North Bay, CA
    From what I have read in the past there are special screws that work like the pins I believe. Do a search and you should find some info about this or others will chime in.
  3. Mr Sunshine
    Mr Sunshine Member
    91
    Dec 12, 2016
    Missouri
    I just removed my trim this weekend and had 1 of the pins break off so I need to know how to replace it as well. I will be researching it as well. Hopefully one of our second gen buddies on here will throw out some wisdom.
  4. steins70z28
    steins70z28 Veteran Member
    222
    34
    Apr 14, 2012
    Tulsa, OK
    Classic Industries lists a replacement screw with sealer #4492963 pg 227 current catalog. 20171106_070106-1.jpg
    tomsti likes this.
  5. dutch73camaro
    162
    34
    Jan 7, 2016
  6. cadillac_al
    cadillac_al Veteran Member
    826
    85
    Apr 22, 2015
    Maine
  7. Mr Sunshine
    Mr Sunshine Member
    91
    Dec 12, 2016
    Missouri
    Awesome, thanks for the info!
  8. 76 camaro car 1
    76 camaro car 1 Veteran Member
    2,387
    Apr 23, 2010
    St.Augustine,Florida
    Just be sure to remember to install the clips before you install the window.
  9. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,319
    Aug 21, 2002
    Central Coast, CA
    I posted this years ago, but Photobucket sucks these days.
    Look up Auveco 9877. A box of 100pcs runs under ten bucks. The resalers are charging a buck for each dime priced screw.
  10. HawkX66
    HawkX66 Member
    84
    22
    Sep 20, 2017
    MI/MA
    Here's what I did on my 69 in case you want to go with welded on studs. I bought a Harbor Freight Stud welder and modified it.
