Window washer motor
Discussion in 'Troubleshooting & Diagnosis' started by Rogerzz, Apr 25, 2018.
  1. Rogerzz
    Rogerzz Member
    35
    Mar 28, 2018
    When I hook up the wiring conectors to the washer motor
    Smoke comes from the wires where the three prong plugs conect. The wiring diagram shows that the blue wires are on top when connecting. They only goes in one way.
    Has anyone had problems like this. What can be done or wrong. Thank you
  2. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    You have a short. That's the only thing that would cause that. If it is happening before you turn on the wipers, I would look for a pinched wire under the cover or something like that. I'm a little surprised it didn't blow the fuse.
  3. Rogerzz
    Rogerzz Member
    35
    Mar 28, 2018
    The problem was he had replaced the washer switch with a on off only switch.
    I replaced it with a time delay switch and purchased the correct motor and pump. It works perfect now. With everyone’s help I finally got the bottom but it took time going thru every step.
    Thank you all for your help. This site has helped me with several things. It’s awsome.
