Windows 10, "My Pictures" ?????
Discussion in 'NastyZ28 Gamers & Computer Gurus' started by CamarosRus, Mar 8, 2018.
  1. CamarosRus
    CamarosRus Veteran Member
    8,485
    139
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    FlaJunkie, I got to HKEY_CLASSES_ROOT
    and there is one line where it says Default Reg SZ (value not set)
    I dont see anything like (Default) of {09799AFB-AD67-11d1-ABCD-00C04FC30936}
    Should anything on that long list be added to that screen
  2. CamarosRus
    8,485
    139
    Feb 16, 2000
    Big Shout out to JIM (Fla Junkie) for fixing my Win 10 issue
    Easy fix but he figured it out
  3. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    OK, we worked this out on the phone.
    Open Settings
    Apps
    Default apps
    Reset to default...problem fixed.
    Apparently some app changed the default app needed to open picture files. That's now fixed.
  4. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    Some application changed it, most likely.
  5. lila
    lila New Member
    18
    Mar 16, 2018
    Very bad.
  6. CamarosRus
    8,485
    139
    Feb 16, 2000
    lila, My above problem was surely caused by operator error (MYSELF)
    I evidently did something that made PAINT the default when I went to open any picture..
    Again, Many Thanks to FlaJunkie (Jim T) for helping me
  7. lila
    lila New Member
    18
    Mar 16, 2018
    I'm glad that this problem is no longer there
  8. Jason Roy
    Jason Roy Guest
    I have read your problem and i think there are 2 causes of that.
    1. You selected the paint as default program to open image.
    2. You don't have any image viewer in your OS.
    So check yous applications and confirm that any image viewer is there. If not then install it.
    If you already have image viewer, then right click and image and select "open with", now select your image viewer application as default opener.
    Source: https://windowsclassroom.com/how-to-get-help-in-windows-10/
  9. ol' grouch
    ol' grouch Veteran Member
    3,094
    866
    Jul 4, 2013
    Evansville, In.
    Alas, Microsoft in it's continuing quest to mess with us and make money doing it will be dropping support for Windows 7 in about a year. We use Windows 7 commercial at work and one of the IT guys told me about that when I had a problem with my computer at work.
  10. Gary S
    22,649
    829
    Not surprising. Software has a short life. Out with the old, in with the new. Usually, the new software is no improvement over the old, but it is newer. And, once a couple of newer versions come out, they can't support and keep up the older ones, so they go down the drain fast.
