windshield trim difference??
Discussion in 'Body Restoration' started by Chuck71RS, Feb 5, 2019.
  1. Chuck71RS
    1,191
    75
    Nov 24, 2012
    Houston, Texas
    For a 71, is windshield trim different when there is a vinyl top vs a painted roof?
    Back in 1986, I really screwed up the trim when I removed it and had to be replaced. The owner of the shop that did the body and paint work got a replacement set and told me there was a difference
  2. BillyDean7173
    BillyDean7173 Veteran Member
    1,036
    144
    May 21, 2014
    Hutto, TX
    Well, at least some of the trim is different for 70-73 cars with a vinyl roof vs. hard top. Rear glass and drip rails as far as I know. Windshield? That's a good question.
    I think there was someone recently looking for trim for a vinyl car and there were a few suggestions on where to buy some.
    I believe the trim is wider on cars with a vinyl top and the drip rails stick out farther to accommodate the vinyl material.
    Hopefully, someone with a vinyl top car will know the answer and can post some pics to show the difference if there is one.
  3. jbloake
    jbloake Veteran Member
    289
    46
    May 1, 2002
    Atlantic Canada
    It looks to be the same part with or without vinyl roof
  4. twozs
    twozs Veteran Member
    8,813
    165
    Aug 5, 1999
    hopewell jct ny
    853C628F-71C9-4F20-B368-7017342BED92.png 4D4DD4E3-A44E-4F99-8AF3-65A01EF47883.jpeg There are 2 for sure . One was standard and the other was Z21 . You can see the with differences here . The lower covers the entire edge ( needed to cover the raw edge of the vinyl roof ) of the C pillar the upper doesn’t .
  5. twozs
    8,813
    165
    Aug 5, 1999
    hopewell jct ny
  6. Chuck71RS
    1,191
    75
    Nov 24, 2012
    Houston, Texas
    Thanks for responses guys but I was asking about the front windshield trim three pieces
  7. 71RSLS
    71RSLS Veteran Member
    579
    108
    Dec 5, 2017
    Prairie City, Ia
    I don't believe there is any difference in the windshield and back window moldings between a vinyl top and non vinyl top. I searched a long while for the moldings for my car and no where did I see any listed for vinyl tops only. Plus, my car used to have a vinyl top but it was removed long ago. The trim was never removed and remnants of the old top were still on the sills and with no top the trim doesn't stick out or leave any gap. I had to replace mine because it was damaged from being hauled. The wind caught the top pieces and jacked them all up.
  8. 70lt1z28
    2,639
    392
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I believe the trim is the same, but the trim clips are a bit taller on the vinyl top cars.
  9. jbloake
    289
    46
    May 1, 2002
    Atlantic Canada
    Look again !
  10. 71RSLS
    579
    108
    Dec 5, 2017
    Prairie City, Ia
    I held my OEM trim clips against some I removed from my parts car that didn't have a vinyl top and they look the same. Both are 71s.
