Winters Sidewinder Shifter
Discussion in 'High Tech Retrofits' started by Bandit723, May 3, 2019.
  1. Bandit723
    Bandit723 Veteran Member
    3,145
    462
    Oct 1, 2016
    Waupaca WI
    So now i do have a question about the cable used. Does this need one specifically for the shifter? If so will it hook up to the stock transmission linkage or are there other parts needed.
  2. 80NastyZ
    80NastyZ Veteran Member
    163
    Feb 8, 2007
    Poconos P.A.
    The shifter comes with the Shifter , cable , and all hardware and brackets for the transmission as well as a Neutral safety switch (only a NSS is included , to get the NSS / Backup combo you will need the part # I gave earlier).
    The cable itself is a Morse style cable and is a bit larger than any cable operated shifters I have had in the past , looks like it will work well for a while. The whole shifter in general is a very well built unit it seems.
    I ordered a spare cable right away (Just like to have spare parts in case .....) , but I don't believe I will ever need it with as much as I drive my car.
    Hope this helps
    TOM
  3. Bandit723
    3,145
    462
    Oct 1, 2016
    Waupaca WI
    Thanks Tom i am sold.
    Mike
  4. Fbird
    3,790
    556
    Feb 12, 2011
    atlanta, ga
    as with our OEM set-ups....make sure you have a ground strap from your motor to the body....don't want to ground out the car using the $60 shifter cable ;)
    looks like the old Cheetah SCS shifter! best shifter i ever used (circa 1990...lol)
