wiper issue
Discussion in 'High Tech Retrofits' started by doublec, Nov 2, 2013.
  1. doublec
    doublec Veteran Member
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    Well...if you look through my progress thread you will see that I cut the stock firewall out and put in a nice smooth one. Looks real nice but I was not thinking ahead and now need to figure out how to mount my wiper motor so it will work properly. I should have just smoothed out the passenger half and left the drivers side where everything hooks up alone, but that ship has sailed!
    So I need all you creative minds out there to help me out. I have a piece of firewall and i could cut a section out and weld a stock piece in there, but was hoping for another solution. I would like to use one of the DSE wiper motors because they look so much better than the factory ones.
    Ideas???
  2. Chris71RS
    Chris71RS Veteran Member
    490
    Feb 26, 2006
    An Island called "long" in the north atlantic
    I have a feeling the DSE wiper motor may work nicely with a smoothed firewall. If you look at their wiper mount, it's basically a flat plate. Other than the mounting screws, you might only have to drill a hole for the motor shaft. I would give DSE a call and see what they say.
  3. doublec
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    I was thinking the same thing Chris..I called them and the guy I talked to seemed to have absolutely no clue what I was talking about :(
  4. Chris71RS
    490
    Feb 26, 2006
    That's disappointing. It's a a little on the expensive side to take the chance on buying it and seeing if you get lucky. Could they e-mail you the installation instructions?
    Edit:Found this install video. Not sure if it's the same motor but might be helpful. http://www.youtube.com/watch?feature=player_embedded&v=R98XtC2weCI
  5. 351maverick
    351maverick Veteran Member
    3,662
    428
    Aug 11, 2010
    erie, PA
    I slather Rain-X on the windshields of my cars all the time & almost NEVER actually turn on my wipers....or do you have an inspection/rule issue?
  6. doublec
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    I have antique tags, so inspection is not an issue..
  7. cars4life
    cars4life Veteran Member
    645
    Jan 11, 2010
    Poughkeepsie N.Y.
    I saw a post once somewhere about a wiper moter hidden on the firewall under the drivers fender. They ran a longer arm from the linkage to the motor.Try a google search for hidden wiper motor mod.
  8. hessdawg
    hessdawg Veteran Member
    316
    Feb 11, 2004
    marina , ca ,usa
  9. doublec
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    I did the majority of work on the car by myself...but this is one of those things I just want to pay someone to do! :)
  10. speed_m5
    speed_m5 Veteran Member
    1,080
    13
    Apr 17, 2010
    Baytown Texas
    under the fender is what we have already spoke of. I did this to a 69 and it work out great
