Wiring Mark VIII fan and DC Controller
Discussion in 'High Tech Retrofits' started by hardline_42, Aug 26, 2006.
  1. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    yeah, there was one member here in the BS section, looking fro Gmachinz b/c his unit burnt out.. that was the only problem I heard of so far. But I contacted him to buy one, and he said he wasnt carrying them anymore b/c of problems.. They are carrying Spal Controllers.. Operate the same way pretty much, as far as ramping up the speed.. So I bought one from him b/c I want a controller, and not use a relay wiring mess to wire up my taurus fan.. Hopefully it'll work.. After buying it, I realized if I had bought a DC direct, I would have saved some $$.. But, if it works and dont give me headaches, I dont care... lol Will post when I get it, hopefully this week.. Good luck with your DC Unit.. Could of just been that one was the bad apple.. who knows..
  2. baskin
    baskin New Member
    Sep 30, 2006
  3. BonzoHansen
    19,503
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    That confirms what Jabin said in another forum - it was not quality issues, but supply issues as to the reason why he stopped carrying them. Based on that exchange, I will not speculate on the supply problem.
    I got mine in just over 2 weeks when I ordered right from DCC. I have yet to install. Steves74 did install his with excellent results.
  4. SpeedAddict02
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    ah, so when he told me he was having problems with "them", he probably meant DC and not the actual product..
  5. Knuckle Dragger
    14,983
    1,444
    Nov 2, 2002
    Waddell AZ
    I'm not sure how different the Crown Vic fan and the Mark VIII fans are, but on my fan the low speed wire goes to a resistor in the fan shroud before the motor.
    I hope that helps.
  6. RS_SS350
    RS_SS350 Veteran Member
    3,259
    Dec 6, 2002
    S.F. Bay Area, CA (East)
    i guess you can check which is high by applying power to each wire one at a time?
  7. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,204
    10
    Jun 10, 2001
    Selah, WA
    Ive acutally had nothing but problems with my delta current control, it actually caught on fire. And yes, I had it wired properly
  8. BonzoHansen
    19,503
    824
    Jun 1, 2005
    That's a first. I never heard that before.
  9. Steve's 74
    Steve's 74 Veteran Member Lifetime Gold Member
    2,734
    Dec 29, 2003
    Long Island, NY
    I ordered mine direct from Brian, he even helped me select the correct parts, it came quickly, and so far it's working great. If design has changed since then, I cannot comment on that product, but my experience with what I have and with Brian was excellent.
  10. blown1981z28
    blown1981z28 Veteran Member Gold Member
    336
    Jan 10, 2007
    Berlin, MD
    It depends on what year your fan is. The later 97 and 98 fans no longer used the third wire. The replacment plug comes with the wire but it is not used. I believe it is just the black and red you will need.
