Wiring Question LS1 PCM
Discussion in 'High Tech Retrofits' started by JJFarmer, May 28, 2010.
  1. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Does the check engine light PCM wire put out 12v (+) or is it a ground (-) to turn the light on when needed? I got ready to wire it in and I didn't have any info on it
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Go on LS1tech and PM John Speartech.
    I don't know, but I know he does.
  3. drptop70ss
    drptop70ss Veteran Member
    700
    Jul 19, 1999
    NY zip 12538
    Normally the ecm will supply the ground, works that way with my LT1 setups, should be the same with LS1.
  4. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Well, I wired it in as a ground and got a light ....so...I guess it is a ground.
