Wiring up my TPI (From '89 FFB) Any input Knuckle Dragger?
Discussion in 'High Tech Retrofits' started by Penix, Oct 15, 2007.
  1. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    So now I find this out....LOL...
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,230
    371
    May 19, 2000
    Los Angeles
    Not sure all of the minor stuff you have to buy for it...
    Higher volume fuel pump
    adjustable fuel pressure regulator
    probably bigger injectors
    2-bar MAP sensor perhaps
  3. ULTM8Z
    9,230
    371
    May 19, 2000
    Los Angeles
    So Dave, have you changed your mind about selling your Camaro then?
  4. Knuckle Dragger
    14,983
    1,444
    Nov 2, 2002
    Waddell AZ
    I've seen a few early cars that generally comand high dollar for sale on the board that are not moving. Great prices but no interest. Something as oddball as my car is certainly not going to bring what I feel it's worth in this market. I'm jonesing for a new project so I figure my Camaro will be that project. I have a good number of things I want to change.
  5. ULTM8Z
    9,230
    371
    May 19, 2000
    Los Angeles
    Very cool. It would have been a sad day to see you part with it.
  6. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    Items 1 thru 3 were on my list at some point anyway, so.....a new map sensor would be the only item left. I understand that buggar is kinda pricey though.
  7. ULTM8Z
    9,230
    371
    May 19, 2000
    Los Angeles
    As I'm thinking about, I'm not absolutely certain a greater-than-1-bar MAP sensor is required.
    In the ECM code if you cross a particular threshold of a combination of MAP and throttle position (TP), it'll send the system into power-enrichment (PE) mode, which you can program with an air fuel ratio you want. The PE is an open loop mode (ECM ignores the O2 sensor feedback) and the AFR will vary with RPM and coolant temperature. So once you're into PE, IIRC, the ECM will ignore the MAP sensor as well. With a blower, you could program the ECM to go into PE at the right MAP and TP for your blower and then make the AFR whatever you want. The critical part will be getting the AFR right- you don't want to go too lean in a blown application. As such, you'd probably want to get a wide-band O2 and stick it in other header tube to see what AFR you're getting in relation to what you programmed into the ECM.
    In fact, the TPS threshold for PE itself varies with RPM and coolant temperature as well. So you could really fine tune this parameter once you start burning your own chips.
  8. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,326
    Aug 21, 2002
    Central Coast, CA
    I was thinking TBI throttle body setup cause the Procharger set up is for carbureted versions, and I can set it up EFI either way, forced or nat. aspirated. I envisioned multi-port because I figure that would give me a little better driveability, low end, mpg, but also cause I figure it could possibly be easier to richen 8 injectors over 2.
    I was trying to imagine whether there would be much of a difference between the cooling effects of mixing the fuel at the top of the intake vs. just before the head... probably better at the top.
    I also like the idea of going with a short throttle body vs. a taller one with injectors and mess. Need to be able to fit all that within the Procharger hat.
  9. ULTM8Z
    9,230
    371
    May 19, 2000
    Los Angeles
    Richening a TB EFI vs port EFI should be the same difference. Just reprogram the ECM. Though yes, the port EFI would give you some better driveability under low-mid range normal dirving conditions.
    WRT cooling, the compressed air is going to be so freaking hot anyway, any cooling differences would be neglibible.
  10. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    POS, Ultm8, Jake....if your putting together a bottom end now(like I am this week)...and the future may include a boosted application...what compression ratio should we shoot for to keep it from being a dog while N/A but not melt itself down when boosted?????
