Won't run worth a @^%$^!!!
Discussion in 'Troubleshooting & Diagnosis' started by 72ss4me, Jun 1, 2019.
  1. Gasoholic
    Gasoholic Member
    60
    30
    Apr 2, 2019
    MI
    Yeah I didn't even think about it being point type ignition. Should have since the OP said it was a stock 72. Just dont think of that first anymore these days. Less I'm working on my lawn mower :)
  2. 72ss4me
    72ss4me Veteran Member
    106
    Aug 11, 2009
    raleigh,nc
    All good advice. I will do the plugs and ignition first. My suv got caught in a hail storm, going to try my luck with PDR do it yourself kit. But, will get to the ss next weekend. Any other suggestions in case ignition isn't it, let me know Also, I fitted a z28 dual snorkel air cleaner on my car. Anyone have a stock ss with all the vacuum line connections noted? I have the original air cleaner as well, but I think the snorkel flap is in opp. Anyway, can't seem to find a clear diagram of proper vacuum line routing in engine compartment. thx.
  3. xten
    xten Veteran Member
    2,808
    1,571
    Sep 24, 2014
    Pittsburgh, Pa.
    Bad gas.
    hubedobeedo likes this.
  4. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    Do a tuneup = points, condensor, cap (with brass rerminals), rotor, wires, an AC Delco spark plugs.
    I suspect that your carb rebuild missed THEE #1 issue with Qjet carburetors = leaking welch plugs in the main body. Did you install an odd shaped black foam piece between the main body and the base plate? If not, the symptom will be starts right up even without the choke. Idles like crap and possibly too high an idle. Fowling spark plugs.
  5. bourbon_scotch
    2,357
    126
    Jan 10, 2003
    USA
    how bout checking the fuel filter
  6. mallard
    mallard Veteran Member
    508
    99
    Oct 3, 2013
    SK, Canada
    Anything new with this problem?
