WTB, 1111997 Distruibtor, 1970 Camaro SS
Discussion in 'Swap Meet Section' started by stafs05, Dec 2, 2019.
  1. stafs05
    367
    21
    Dec 26, 2007
    chicago,IL
    Hello , I would like to purchase a distruibtor 1111997 with a date code of F70, or possible late E70. Or if anyone has company, or person that sells these. As always thank you.
  2. Gary S
    22,508
    786
    I should have one in my stash, but it is an early one from Oct, Nov 69. I'd have to pull it out to see for sure on the date.
  3. stafs05
    367
    21
    Dec 26, 2007
    chicago,IL
    Hello, Thank you Gary for your help again. But I do have one. Im looking for a date code correct. Thank you any.
  4. DCL70
    DCL70 Veteran Member
    1,234
    8
    May 5, 2007
    Merrimack, NH
    I have about 20-25 Chevrolet V8 distributors in my garage attic that I have collected over the last 30+ years. According to my notes I have a 1111997 distributor dated 0D29 (April 29, 1970) but I would have to check in my garage. We just got 24" of snow on Monday & Tuesday. I realize that this is a bit early for your needs but if interested send me a PM.
    Dave
  5. Gary S
    22,508
    786
    You have quite a big window of time for the distributor. The one I have here is dated July 21,1969 and I took it out of a Caprice built in Oct-Nov of 1969. This distributor was likely from the first AC Delco production run for the 1970 model cars as it predates the first 1970 cars off the assembly line by at least a month, and it predates the actual car it was installed in by 4 months or so.
    The distributor has to predate the engine and the engine has to predate the car assembly date.
  6. 70RSZ28hugger
    70RSZ28hugger Member
    77
    Nov 30, 2006
    San francisco bay area
    I have 70 Z28 which i believe uses 2019 or 1997 one you have its correct date .
  7. stafs05
    367
    21
    Dec 26, 2007
    chicago,IL
    No I dont have the correct date, as far as I know the 350 SS uses 1111997 only.
    Just answer your lock issue.
  8. stafs05
    367
    21
    Dec 26, 2007
    chicago,IL
    Thank you for everyone in put. My engine is was built in E25, 26,. So I dont know I thought going by my built date. I didnt know when they stopped making the 1111997. These 1970 Camaro I have no clue when they stopped started parts. So maybe I need E or D 1970 one. Again thank you everyone.
  9. 70lt1z28
    3,367
    662
    Oct 3, 1999
    Beavercreek, Ohio, USA
    70 Z uses the 2019 only.
  10. Gary S
    22,508
    786
    With an E25 engine, the D29 distributor that DCL70 has would work just fine for you, but as I stated earlier, you could also use any distributor from a couple of months earlier if needed and still be correct.
