WTB: Aluminum Radiator LS
Discussion in 'High Tech Retrofits' started by Protour-Camaro, Nov 19, 2014.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    What fans did you use? I don't want something that looks made to work. I would like it to look presentable like the fans were suppose to be there.
  2. Kamaro
    Kamaro Veteran Member
    277
    Oct 31, 2010
    Doha
    I'm using a Griffin LS radiator designed for 2nd Gens with LS engines, it cost $267 and works quite well. It has both in and out from the passenger side and fits just like the original with the 4th gen dual fans.
  3. Bill70
    Bill70 Veteran Member
    233
    11
    Jan 8, 2012
    Phoenix, AZ
    I am using 2 Spal 12" fans with an aluminum shroud I bought online. Should look show ready when I finish installing them. BTW I will have accomplished for $500 what eveyone out there is selling for $700-$1500.
  4. 71RS/SS396
    71RS/SS396 Veteran Member
    2,623
    27
    Aug 26, 2008
    Wake Forest NC
    I warned you! :D
  5. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Do you have parts #s and pictures by chance?
  6. Protour-Camaro
    2,111
    Feb 16, 2012
    California
  7. Bill70
    233
    11
    Jan 8, 2012
    Phoenix, AZ
    Here you go:
    radiator: Griffin 8-00010-LS $267
    fan shroud: CFR Performance HZ-1008-31 $90
    fans: Spal 30101522 $89 each from Amazon
    fan harness: Spal FR-PT $9 each from Amazon
    For those who don't know Amazon sometimes has products as much as 50% less than Summit Racing. The Summit price for the fan is $135 each.
  8. MacLoGoS
    MacLoGoS Veteran Member
    183
    Mar 31, 2014
    San Francisco
    I plan on getting this same rad for my ls1 swap. Would the stock efan setup for a 2000 camaro bolt to this rad?
  9. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Interested to see the final product!
  10. Bill70
    233
    11
    Jan 8, 2012
    Phoenix, AZ
    I didn't bolt anything to the radiator itself. I made my own brackets which are attached to the core support. Basically you can make anything work if you are creative enough. Pictures below are the setup I fitted to my car. Not the cleanest but it will get the job done.
