WTB: Original Small Block Exhaust Bolts, Hose Fitting
Discussion in 'Swap Meet Section' started by Mulsanne Blue, Aug 9, 2019.
  1. Mulsanne Blue
    Mulsanne Blue Veteran Member
    218
    Mar 31, 2009
    Goshen, Indiana
    Need up to (12) original bolts. Prefer the pictured head C marking and unrestored. Will consider different other than double "O". 3/8-16 X 2.27 9/16 Hex.
    Need (1) Heater Hose Fitting Intake 5/8 Hose X 1/2 Pipe w/Hex Notches.
    5:8 heater hose fitting.jpg
  2. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,209
    38
    Jan 1, 2005
    Schererville,In.46375
    I should have the manifold bolts that are NOS ones... Ill check today.
  3. Mulsanne Blue
    218
    Mar 31, 2009
    Goshen, Indiana
    PM SENT
  4. Mulsanne Blue
    218
    Mar 31, 2009
    Goshen, Indiana
    Still need all...
  5. Mulsanne Blue
    218
    Mar 31, 2009
    Goshen, Indiana
    Got lucky on a different site, scored a set of near perfect early take off exhaust bolts with the "C".
    Still need the fitting.
  6. 70lt1z28
    3,311
    649
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Was that on the Yenko.net site by chance?
  7. dave@ztech
    3,394
    701
    Mar 27, 2016
    NY
    That has to be a miracle ,finding the exhaust bolts, as I was looking at the ones I have , that I would give to you, unrestored, and they look like holy hell, they have had so many heat cycles and water , they look like something that held together a pirate's three lock box. HAA HA
  8. Mulsanne Blue
    218
    Mar 31, 2009
    Goshen, Indiana
    Lucky indeed. Must have been off a car soon out of the showroom that had a header swap. How they were saved and not pitched is beyond me. Now the quest is to find the steel small OD washer/spacer that accompanies the bolt and french lock. Reproductions are stainless and the OD's are to large. Should be about 0.68-0.69, reproductions are closer to 3/4.
  9. CamaroDoc
    CamaroDoc Veteran Member
    1,983
    90
    Sep 13, 2003
    Skiatook, Okla. 74070
    I hang on to stuff like that. Let me check my bolt bins...
  10. 70lt1z28
    3,311
    649
    Oct 3, 1999
    Since the OP found his set anyone have another set for sale?
