wtb, rear disc brake fittings
Discussion in 'Swap Meet Section' started by 71rs72012, Sep 29, 2015.
  1. 71rs72012
    71rs72012 New Member
    10
    Jul 17, 2015
    beebe, ar
    :( After taking over a project when I got my car I found out it has rear axle from a 79 firebird with disc brakes...however it had no calipers. Upon replacing the calipers I learned of some apparently very rare brass fittings that connect the calipers to the hard lines. Needless to say I can't find any...was told could only get them off of a car that already had them on it. Anyone have any? Or any other ideas?
    http://img.photobucket.com/albums/v159/67SS427/bottomrestorearendb-1.jpg
    Above is a link featuring the brass block I am referring to...
  2. badazz81z28
    17,379
    604
    Alabama
    I would think a rubber banjo type hose would work. If you find some blocks, expect to pay $50+ for them.
  3. 71rs72012
    10
    Jul 17, 2015
    beebe, ar
    I'd pay the $50 for them at this point....
    I've already spent the money for the factory bent hard lines so I was trying to get the factory blocks. If I don't find some soon I guess I will have to have new hoses made.
  4. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    I might be interested in selling you mine....I have rear TA disc on my car, but expect to upgrade to C5 or BAER. Are you in need of JUST the blocks? I also have scarebird metal arms on my calipers.
    If you are so inclined, what you do is run a short banjo hose from the caliper to about 4-5 inches inward. Cut the factory brake line, flare it and connect it to the hose. You will need to find a way to secure it all from moving around.
  5. 71rs72012
    10
    Jul 17, 2015
    beebe, ar
    I am going to try a rear brake line from a 2000 blazer today, if I cant get that match up I will definitely be interested in your blocks. and, yes, the blocks are all I need...
  6. Shizzle
    Shizzle Veteran Member
    2,628
    644
    Aug 1, 2012
    oak lawn, illinois
    try front brake lines for a chevette. that is what is commonly used when doing a rear disc conversion on a 14 bolt rear axle.
  7. NorCal_71
    NorCal_71 Veteran Member
    382
    9
    Jul 7, 2008
    Santa Rosa, CA
  8. 71rs72012
    10
    Jul 17, 2015
    beebe, ar
    for some reason I think a chevette may be just as hard to find parts for as 79 firebird or 79 Seville are...haha
    I have searched the area for cadillacs being parted out to with no luck
  9. Shizzle
    2,628
    644
    Aug 1, 2012
    oak lawn, illinois
    I've gone to the parts store and bought chevette brake lines no problem.
  10. 71rs72012
    10
    Jul 17, 2015
    beebe, ar
    I will for sure keep that in mind if the S10 ones don't work. Any year in particular?
