WwhT is the best 383 starker kit?
Discussion in 'Engine Topic' started by earnhardtgm3, Aug 15, 2013.
  1. earnhardtgm3
    earnhardtgm3 Veteran Member
    2,473
    33
    Dec 18, 2007
    Camaro Country,GA
    What is the best 383 starker kit?
    My dad wants a 383 with all the same stuff that I have in my 355 as in my signature.What is the best stroker kit for a 383
  2. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    Not sure what a "STARKER KIT" is but an Eagle or SCAT STROKER kit are excellent products.
    OR he can buy a Genuine GM 383 that has a 4.000" bore and a 3.800" stroke.
    Buy it as a short block, change cams add heads etc like yours and he's done.
  3. earnhardtgm3
    2,473
    33
    Dec 18, 2007
    Camaro Country,GA
    Sorry for that .Corrected it. He already has good block
  4. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    Then the first sentence of my post applies. Summit, Jegs, Northern Autoparts ETC sell the kits and you can use 5.7 or 6" rods, Forged or Hyper pistons, dished, flat or domed pistons. 5/64" or 1/16th rings. The choices are endless and the parts are good.
  5. ProStreet383
    ProStreet383 Veteran Member
    2,106
    9
    May 23, 2007
    MD
    http://www.summitracing.com/parts/sca-1-40755bi/overview/
    4340 Forged Standard Weight Crankshaft
    4340 Pro Comp I-Beam Connecting Rods with ARP 7/16" Cap Screws
    Icon Forged Pistons
    Rod Bearings and Main Bearings
    Premium Plasmamoly Ring Set
    Rotating assembly is Internally Balanced
    Compression Ratio with 58cc 11.8:1
    Compression Ratio with 64cc 11.0:1
    Compression Ratio with 76cc 9.6:1
    Everything all in one kit and ready to drop right in your block.
    OhioCrankshaft also has some nice kits.
    http://www.ohiocrank.com/chevsb_rotate.html
  6. earnhardtgm3
    2,473
    33
    Dec 18, 2007
    Camaro Country,GA
    Found out the block is already bored .030 over stock.So I need to find a kit for .040 or should he go .060 over?What is the big difference between the cast set vs forged set.His car will be a street driven car.Need to compression down for pump gas.Want to keep around 10:1 compression.Any input appreciated.
  7. 1981zapper
    1981zapper Veteran Member
    1,317
    Apr 28, 2009
    Southern Ontario, Canada
  8. earnhardtgm3
    2,473
    33
    Dec 18, 2007
    Camaro Country,GA
    Is it best to go internal or external?Already have the stock harmonic balancer and flexplate.
  9. ProStreet383
    2,106
    9
    May 23, 2007
    MD
    The skipwhite kit is a good kit if you get them to switch to the better scat pro comp rods. The probe pistons are very strong, hastings makes good rings, the scat crank is good and the king bearings are excellent. Cant really go wrong with that kit if you get it with the better rods.
  10. ProStreet383
    2,106
    9
    May 23, 2007
    MD
    Internal is best. Call up skipwhite and see if they will do the above kit with scat pro comp rods and .040 probe pistons.
