Yippie, paint is done :)
Discussion in 'Oklahoma Region' started by gutted72, Jun 11, 2019.
  1. gutted72
    gutted72 Veteran Member
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Thanks COPO.
    I should be able to finish up the backend on Wednesday and then move onto the interior or the front end, haven't decided which one to do yet.
  2. Scott Sievers
    Scott Sievers Veteran Member
    209
    95
    May 22, 2018
    SE Iowa
    Light sanding and a buff job will fix the run in the clear.. and having done it yourself you saved a CRAP load of money, and now, you have the satisfaction of saying YOU did it... Thats one sharp car!
  3. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Thanks Scott, the run is on the left front fender by the side marker. It should be a simple fix, now I just need some sandpaper and a buffer. Probably do it after I put the front end stuff back on.
  4. sprink
    sprink Veteran Member
    498
    117
    Apr 27, 2008
    ffx, va
    Nice. Bet that combo looks awesome in the sun.
  5. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Sprink,
    I looks like a glitter bomb went off. All that matters to me is the wife really likes the color.
    I can't get a picture that really shows how much metallic is actually in this paint, but it's a bunch.
  6. mrfleet12
    mrfleet12 Veteran Member
    249
    54
    Aug 8, 2014
    West of Chicago IL
    Looks great, has to be a good feeling getting to this point.
    Fleet
  7. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Fleet,
    Thanks.
    It does feel pretty good, just wish I was driving it already, but I WILL be driving it this year :)
  8. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Finally blew up that dang kidney stone yesterday :oops: so today I got a few things done. Doesn't look like a whole bunch but at least it's something.
    All the side markers are on, passenger door handle and lock stuff all in
    Got almost all the front end stuff back on, still working on the hood latch and missing a few of the headlight trim screw doodads
    71RSLS and shanghai Kid like this.
  9. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Question,
    Has anyone put in new door latches and had a hard time using the key to unlock it? If so does it loosen up over time?
    I have lubricated the crap out of the latch and it still is hard to turn the key, I don't want to snap the key off.
  10. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    I figured out my problem with the locking.
    The latch actually works really good, it's the piece that you pull up or push down in order to lock the latch. I replaced the worn out plastic bushings that hold the rod to the door and the new ones are really tight on that rod. With that rod bushing so tight it won't allow the key to unlock or lock the door latch.
    No pictures of today's fun. Just putting all the window channel, weatherstrip, and other door stuff back on.
    dave@ztech likes this.
