Youre take on this hood rust
Discussion in 'Body Restoration' started by 80sz, Jan 20, 2017.
  1. 80sz
    80sz Veteran Member
    3,160
    415
    Feb 2, 2014
    Buffalo,n.y.
    All metal body filler,just watched video on it. Good stuff.
  2. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Be carefull with all metal filler. It does not expand and contract well with heat changes. I would stick to the basics here.
    1. Sand blast
    2. Make sure metal is not to thin
    3. If it is and you want this hood cut out the rust spot and weld in new metal off another hood
    4. If metal is not to thin epoxy it. Fill with quality plastic filler, seal prime and then filler primer.
    bodymanbill likes this.
  3. 80sz
    80sz Veteran Member
    3,160
    415
    Feb 2, 2014
    Buffalo,n.y.
  4. 80sz
    80sz Veteran Member
    3,160
    415
    Feb 2, 2014
    Buffalo,n.y.
    Got the paint off. Rust spots arent that bad arent good. I called the painter said hed stop by and look at it if in area.tomorrow Im going to see what this rust remover does.
  5. Hey G
    Hey G Veteran Member
    519
    Mar 18, 2012
    SC
    That hood looks great as is...if it's original metal I would keep it with the car. The rust looks very minor from what I can see. Some good quality body-work and you will never know it was there, and it will last for years to come...I am sure. Just my two cents.
    G
  6. 80sz
    80sz Veteran Member
    3,160
    415
    Feb 2, 2014
    Buffalo,n.y.
    Thx! I think after I treat it should be almost gone. What's epoxy ? I don't know what it is. Is it sprayed onto surface of rust before I do filler of any kind? I saw a can of it last night at store . I don't know if that's what I need . Is said it stoped rust further. Was vht epoxy frame paint ,at pep boys.
  7. Bandit723
    Bandit723 Veteran Member
    3,148
    463
    Oct 1, 2016
    Waupaca WI
    Do you plan on having a body shop paint this? if so I would ask them what coatings are compatible with the paint systems they use before doing anything.
  8. 80sz
    80sz Veteran Member
    3,160
    415
    Feb 2, 2014
    Buffalo,n.y.
    I won't be painting. Just need get something on it so it won't surface rust over next few months of winter. Im going to dust it with some etch primer and leave it up to body shop.
  9. junkyardZ28find
    783
    8
    Mar 4, 2012
    des moines, iowa
    Metal 2 Metal filler is what I would recommend. I am a body guy as well as a harness builder and I've used it before without any issues. I'd suggest saving that GM hood no matter what-it will always be a better fit that anything aftermarket.
  10. 80sz
    80sz Veteran Member
    3,160
    415
    Feb 2, 2014
    Buffalo,n.y.
