Yup, another LS1 thread!
Discussion in 'High Tech Retrofits' started by jb451, Jun 21, 2012.
  1. andrew69_04
    andrew69_04 Veteran Member
    254
    Jan 8, 2012
    Berthoud CO
    Im running a gto ls2 with swap plates and my accessories all clear. Only issue i had was with the alternator and the pitman arm. I swapped to the f-body alt and my problem was solved.
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    I havent heard of these issues.
    BRP trans crossmember is a POS IMHO
  3. jb451
    jb451 Veteran Member
    861
    Jan 17, 2011
    Mesquite, Texas
    I know of at least two threads that that has happened. Either the person has pitman arm clearance issues plus they have to notch the frame for the ac compressor or relocate it with the dirty dingo brackets.
    Why no love for the brp x member and what else would you recommend?
  4. andrew69_04
    254
    Jan 8, 2012
    Berthoud CO
    Transdapt swap plates, stock motor mounts and the stock x-member moved back. Its simple, cheap, and works great
  5. jb451
    861
    Jan 17, 2011
    Mesquite, Texas
    Just move it back or move it back and flip it around 180 degrees? Ive heard it work both ways.
  6. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    VATS is for the Vehicle Anti Theft System and has nothing to do with the gear ratio/tire size. That's the duty of the VSS (Vehicle Speed Sensor) and its correlation with the PCM.
  7. jb451
    861
    Jan 17, 2011
    Mesquite, Texas
    Let me ask you guys this, what about using an inline fuel pump? Anyone here run them, sbc or ls? Pros-less labor intensive, probably a little less expensive. Cons- ive heard its loud, pump failure are two big issues.
  8. jb451
    861
    Jan 17, 2011
    Mesquite, Texas
    Also andrew (or anyone else for that matter) can you post up pics of those swap plates if you have them?
  9. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    If you run an inline pump and NOT baffle the tank, you will will kill the engine at low fuel levels, hard braking, turning.
    You need a good tank!
    The BRP crossmember is nothing special. Its nothing more than a round tube pipe bent in the middle. Get this, the mounting tab was in the middle and the Camaro drivetrain is slightly offset. Plus they are EXPENSIVE! The Stock cross member is my option. These adapter plates are only $30!
    http://www.ebay.com/itm/LS1-Convers...pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
    Look on Ebay, Tons of people are making them.
  10. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Thats not from the mounts and I doubt BRP solves that. Just the fact of where the alternator location on F-body/GTO LS1 Accessories.
    I researched the smaller Camaro alternator clears fine.
