Yup, another LS1 thread!
Discussion in 'High Tech Retrofits' started by jb451, Jun 21, 2012.
  1. andrew69_04
    andrew69_04 Veteran Member
    254
    Jan 8, 2012
    Berthoud CO
    Ive run an inline pump on two builds. Both tanks we sumped. Both pumps were noisy. We ran Aeromotive A1000 pumps.
    As far as the mounts are concerned, i think i have a few pics in my build thread
  2. jb451
    jb451 Veteran Member
    861
    Jan 17, 2011
    Mesquite, Texas
    Did i read it wrong or did you have to trim something up to make it fit? Very, very nice build btw! I want an ls2..... too bad i cant afford it.lol
  3. andrew69_04
    254
    Jan 8, 2012
    Berthoud CO
    I had to do a little grinding on the very top of the castle nut on the pitman arm, and a little to the alt housing. If I had used 1" setback mounts like most others have, it would have cleared.
    The only thing we could not make fit was the A/C. I notched the frame as much as I could before we dropped the motor/trans in and it was not enough. We're just going to run the S&P setup with the sanderson compressor in the high mount location
  4. WTR's camaro
    WTR's camaro New Member
    23
    Jul 3, 2012
    Little Rock AFB, Arkansas
    are u looking to rebuild the motor..cause i dont think u will get a motor with under 125k for that...well not with a tranny...i mean u could get lucky but expect to cough up around 4k for both...well any motor with decent milage
  5. muncie21
    muncie21 New Member
    10
    Jun 8, 2009
    NE, Ohio
    what about the wiring harness?
