Z/28 stripes; is this wrong?
Discussion in '1970 - 1973 Specific' started by DanSaco, Sep 29, 2019.
  1. DanSaco
    DanSaco New Member
    26
    Apr 5, 2019
    80DAACA5-EE06-4839-B19A-F2157687F157.jpeg Saw this for sale today right near my house, and because it’s nearly identical to my 70 Z, I stopped to look at it. I’ve read up a lot on the correct stripes, I’ve seen this done before but never seen anything to indicate it was correct. What I’m referring to is where the nose stripes terminate at the front, on the inner corner I believe it should be a curve, not a sharp turn.
    Very sharp car, great paint, white interior looks wrong and the green dashpad is definitely wrong. Z/28 emblems are all brand new which just looked suspicious to me. Not interested in buying another one, just being nosy and I’d love to be better at identifying a clone.
    Btw, they’re asking for $30k 1973 with 350/400
  2. mallard
    mallard Veteran Member
    503
    96
    Oct 3, 2013
    SK, Canada
    I googled a pic of a 73z and it had a gentle curve on the inside edge.
  3. DanSaco
    DanSaco New Member
    26
    Apr 5, 2019
    My friend has a 73 Z/28 and it looks like this, but I’ve always thought it was wrong. I know he had them repainted when he put a cowl hood on, and he had the body shop redo them because they came out wrong the first time, something about the stripes having no taper. Idk why you wouldn’t look up some reference photos or GM manual or something. Especially when the body shop owner is a camaro guy. Owns two 69s and a 67.
  4. 70lt1z28
    3,311
    649
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Chevelles of this era had the sharp inside corners. Incorrect on a Camaro.
  5. bodymanbill
    bodymanbill Veteran Member
    1,262
    616
    Feb 1, 2007
    South Park Pa
    image.jpg Definitely should be rounded like mine. Since it looks to be a 73 u can tell a Z from the VIN
  6. G72Zed
    G72Zed Veteran Member
    1,079
    233
    Sep 8, 2015
    I used the GM spec sheet out of the build manual as per attached.
    Due to the cowl hood, I did not use a stencil kit and laid it out with 1/4” fine line tape following GM specs.
    As bodymanbill states above, should be rounded to be correct.
    99F6213C-23C9-424B-BA6F-091B6641B554.jpeg 91D2F553-ABE6-479A-B0B7-FEFEE6E68ED1.jpeg
  7. Smokey15
    Smokey15 Veteran Member
    3,026
    1,216
    Aug 13, 2017
    Caledonia, MI
    We used a stencil from Stencil's & Stripes. They are to factory specs.
  8. COPO
    17,682
    683
    All 1970-73 Z28 front end stripes had rounded corners.
  9. roeville
    roeville Veteran Member
    1,228
    84
    Oct 9, 2000
    SF East Bay CA
    This is not that difficult to fix. An educated buyer would use this for a slight discount.
  10. G72Zed
    1,079
    233
    Sep 8, 2015
    If this "38k mile survivor" with it's as noted original paint shows is indeed true, it does follow/support the GM spec sheet I attached a few post's ago.
    FWIW, I obviously know now that my "hand laid" stripes are too large of a radius on the inside turns.
