Z28 trim ring install
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Bills69, Dec 4, 2019.
  1. Bills69
    Bills69 Veteran Member
    108
    May 28, 2018
    just curious how everyone installs trim rings with out denting them ?
  2. BillyDean7173
    BillyDean7173 Veteran Member
    1,549
    295
    May 21, 2014
    Hutto, TX
    I install my rings with the tire off the car.
    I let some air out of the tire, use just a bit of dish soap on the clip for lube, a thick towel and rubber mallet. Just tap each clip into place, sometimes moving from one clip to the next in a circular pattern (take your time). Then I mount the tire, let the car down and air the tire back up.
    Doesn't hurt to have an extra set of hands to hold the trim ring when installing.
    I'm sure you'll get several methods of installation.
  3. COPO
    17,736
    693
    I use the palm of my hand. If it won’t go on then I let 1/2 the air out.
  4. Gary S
    22,508
    786
    Like the others here, I first let some of the air out of the tire. With the tire soft, I push each clip firmly onto the rim using a large flat screwdriver. Push directly on the clip, never on the ring itself. Once you have all the clips firmly seated, put proper air back in the tires.
  5. Bills69
    108
    May 28, 2018
    thanks always open to new ideas
