ZF 6 speed swap
Discussion in 'High Tech Retrofits' started by dan_e, Jun 28, 2008.
  1. dan_e
    dan_e Veteran Member
    121
    Nov 11, 2007
    wilmington, ma
    Hey guys, i'm looking to swap a zf 6 speed from the lt4 vettes into my 79z and bolt it up to my 327. is this any more difficult than a typical tranny swap? anybody done it? i can find the zfs for pretty cheap and they seem to have a good reputation around them but i dont wanna just grab it and not be able to bolt it up. suggestions help thanks.
  2. amargari
    amargari Veteran Member
    1,241
    17
    Feb 19, 2003
    Morristown, NJ, USA
  3. camaro450hp
    camaro450hp New Member
    28
    Feb 1, 2007
    oklahoma city
    I have a zf too sitting in my garage i am putting in mine it didn’t look much bigger than the t56 that I had bought to put in my car
  4. BonzoHansen
    19,648
    906
    Jun 1, 2005
    Scott from Hamilton, NJ
    The T56 is a big trans too. Check the trans forum for some other users' swaps.
  5. John Wright
    14,716
    216
    Aug 9, 2002
    Rustburg, Va
    I can vouch for the T56 being heavy......
  6. 68400BIRD
    68400BIRD Veteran Member
    2,955
    12
    Feb 7, 2006
    GO PACK GO
    That or you being weak,:crazy: :D
  7. John Wright
    14,716
    216
    Aug 9, 2002
    Rustburg, Va
    I toted that thing about a couple hundred feet by the input shaft and the tail shaft while it was raining(so I was going as quickly as I could) across my yard and down the basement steps and sat it on two cinder blocks and I thought my arms would fall off before I could get it set down.....don't even have a guess at the weight, but I'm betting it is over a 125# easily....
  8. 79ZED
    79ZED Veteran Member
    3,085
    9
    Jan 31, 2000
    Nanaimo, B.C., Canada
    Good guess John. TTC lists the weight at 122 lbs. Not sure if that's with the bellhousing and shifter tho....:)
    John
  9. 68400BIRD
    2,955
    12
    Feb 7, 2006
    GO PACK GO
    So how much more is that than a turbo 350,400 or a manual set up? At least the weight transfer is so close to the middle of the car that it should equal out quite a bit.
  10. John Wright
    14,716
    216
    Aug 9, 2002
    Rustburg, Va
    Rob I used to hold my BW T-10 up with one hand, laying on my back, under my Corvette while reaching for wrenches with the other hand, so I'd say that there is a considerable difference in weight between those two trannys.
