1 piece rear main seal BBC installation help
Discussion in 'Engine Topic' started by Johnny Blaze, Nov 1, 2014.
  1. Johnny Blaze
    Johnny Blaze Veteran Member
    930
    27
    Jan 24, 2013
    New Washington, IN
    I am finishing up my GEN 6 BBC build. First time working with a GEN 6.
    I got a Fel Pro One Piece Rear Main Seal for it. It appears to be two seals, one inside the other. The package listed an installation tool , which seems to not be available any longer.
    Can anyone help with the install? Which way does the seal go? Any tips on getting it in without damaging the seal? They are kinda pricey!
    Pics would be great!
    Web search was not very helpful.
  2. krabben1
    8,245
    72
    May 16, 2007
    ( . Y . )Delco
    My gen VI one piece seal was one piece,thats it.No special tool needed..
    It pushes in with your fingers,after pan is installed.
    Did you get the felpro Viton seal?
    Sounds like somethings wrong.
    You didn't get a conversion seal for a one piece did you?
    Ill try to find a pic of mine.(circa 2009 gen 6 454 crate motor)
  3. troutman
    troutman Veteran Member
    121
    Mar 16, 2009
    Chapin,S.C.
    I use to install these type seals on the 8.1 BBC. Also had the special tool to install to prevent warping the pricey seal.
  4. krabben1
    8,245
    72
    May 16, 2007
    ( . Y . )Delco
    The blue is the oil pan gasket,the brown is the rear main.
    Old GM seal.
  5. Johnny Blaze
    930
    27
    Jan 24, 2013
    New Washington, IN
    I'll get pics and part number later today.
    It is a felpro, and was what came up at the parts store.
    Not a conversion.
    But it has a smaller seal that fits inside the larger, if that makes sense.
  6. troutman
    121
    Mar 16, 2009
    Chapin,S.C.
    You must be working on an 8.1L.
  7. Johnny Blaze
    930
    27
    Jan 24, 2013
    New Washington, IN
    It's a 454, but I think the double seal seems to be for the 8.1
  8. troutman
    121
    Mar 16, 2009
    Chapin,S.C.
    Yep, that would be your problem. Exchange it for a gen5/6 B/B one piece seal.
