10 bolt to 12 bolt swap 1970
Discussion in 'Transmission & Driveline Topics' started by Me_n_my_z, May 18, 2017.
  1. Me_n_my_z
    Me_n_my_z Veteran Member
    277
    8
    Jan 2, 2011
    Cleveland, Ohio
    Im swapping the rear end on my 70.
    Its got the factory 8.2 10 bolt.
    I found a 3.08 COS code 12 bolt from a 70 SS350 and had it rebuilt by a local builder.
    The question is, will it be a direct swap or will i have to buy a special u-joint for it.
    I had a factory 3 series posi unit installed too.
  2. Zspoiler
    Zspoiler Veteran Member
    3,779
    366
    May 6, 2012
    Federal Way, Washington
    As long as it both from 2nd gen Camaro`s it will bolt right in.
  3. big gear head
    big gear head Veteran Member
    6,306
    134
    Jul 30, 2001
    Central City, Ky.
    10 bolt and 12 bolt used the same drive shaft and same 1310 U joint. A few special bolt rear ends were built with the 1330 yoke, but they are not very common.
    That's a Yukon Dura Grip, not a Eaton Posi. Factory differential was the Eaton. The Yukon is almost an exact copy of the Eaton.
    Me_n_my_z likes this.
  4. Me_n_my_z
    277
    8
    Jan 2, 2011
    Cleveland, Ohio
    Thanks. Ok. I thought i was factory, but i looked at receipt and you are correct.
    When i talked to him i was under the impression it would be a GM unit.
    But all the same i guess. As long as both tires spin. Lol
  5. big gear head
    6,306
    134
    Jul 30, 2001
    Central City, Ky.
    There is nothing wrong with the Yukon unit. Eaton parts interchange with it, so if you ever need to replace anything in it you can get Yukon or Eaton parts for it.
  6. badazz81z28
    19,215
    1,091
    Alabama
    You had it rebuilt? Did you upgrade the yoke?
