12" rubber hose rule
Discussion in 'Competition Camaros' started by arick793, Jul 8, 2013.
  1. arick793
    arick793 Veteran Member
    1,127
    Oct 27, 2008
    Rochester, NY
    One by one IM taking care of little projects to get my car ready for tech inspection. I know there is a rule saying that you must have a total of less than 12" of rubber fuel line on the whole car, how do you guys manage that? I have a stock fuel line from the tank to the fuel pump. I have a hard line from the pump to behind the alternator, then rubber hose connecting it to a filter, and rubber hose connecting the filter to my carb. If you count the hose to the fuel pump, the hose connecting the two hard lines at the subframe, and the hose connecting hard line to the tank, IM waaaaay over the limit
  2. HyPer
    HyPer Veteran Member Lifetime Gold Member
    738
    Mar 19, 2012
    Central Mississippi
    Good thing we don't have inspections here.....pay my water bill this month, and take them the receipt and get a Mississippi license plate. ;)
  3. CorkyE
    10,919
    696
    I ran AN-6 line from the pump to regulator then to carburetor. I don't know if they'll count the factory installed lines but eliminating rubber in the engine compartment should get you by.
  4. K5JMP
    10,216
    10
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    from tank to carbs, is all -8AN on my car.. even the return.;)
  5. bracketracer-78
    bracketracer-78 Veteran Member
    731
    65
    Sep 5, 2003
    Stevens, PA USA
    I ran the stock fuel line to the engine compartment. Then i used braided steel line from the stock steel fuel line the rest of the way. I never had any issues with tech and my local track is a bunch of tech nazi's. Im now running approved pushlock the whole way from the fuel cell to the fuel regulator, then braided steel the rest of the way.
  6. Mike N
    2,903
    629
    Jan 13, 2002
    Spencerport, NY.
    I think what they're looking for is no more than 12" in a single span. Keep the rubber to a minimum and you'll be ok. They're not the most strict at Empire.
  7. mrdragster1970
    7,821
    507
    Apr 12, 2007
    They want the hose clamps off more then the hose in my book.
    As mentioned, getting all the rubber away from the engine & moving parts should be mandatory!!!
    Especially now a days with all the light weight, press on certified lines out there,
    there's no excuse not to have ZERO rubber hose.
    12" should be easy to accomplish!!
    Good luck.
  8. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    No.
    Rule is: 12" total. And as said above, there is no excuse for having any rubber line, (or plastic/glass filters, imo). At the very least, use braided just as you would rubber and hose clamp it on your hard lines.
    Shouldn't be hard to replace this with one piece of -6 braided and a couple fittings.
  9. muscl car
    22,789
    1,385
    Jul 8, 2001
    SoCal High Desert
    a friend of mine and member here "Cataldo" was questioned in Tech about the rubber hose between his regulator and carb . Even though it was Russell twist lock hose and using hose clamps the tech said the hose was not legal !!!!!:confused: :confused:
  10. bracketracer-78
    731
    65
    Sep 5, 2003
    Stevens, PA USA
