15x8 Rally Wheel Backspacing Help
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by SlowJammin, Nov 7, 2013.
  1. SlowJammin
    SlowJammin New Member
    Nov 7, 2013
    Los Angeles, Ca
    I'm interested in buying 15x8 corvette type rally wheels for my 73. I seen some for sale with a 4.25 backspacing. I don't want the wheels sticking out. Is 4.25 backspace enough?
    Do 1st gens have less room than 2nd gens as far as wheels go?
  2. andy736
    andy736 Veteran Member
    722
    Sep 14, 2008
    s wisconsin
    15x8 for front and rear? 4.25 may be close depending on tire size. Most run 4.5 bs.
  3. SlowJammin
    Nov 7, 2013
    Los Angeles, Ca
    It would be for both front and back.
  4. GoldenOne7710
    5,311
    717
    Jun 23, 2004
    Athens, GA
    Factory 15X8" Corvette Rally style wheels are all 4.25" back spacing and fit easily on 2nd Gen Camaros. The N90 style wheels were also 4.25" back spacing. A 235/60R15 tire works good on all 4 corners.
  5. SlowJammin
    Nov 7, 2013
    Los Angeles, Ca
    Awesome. Now do you think 255 or 275 would fit?
  6. CamaroDoc
    CamaroDoc Veteran Member
    2,197
    240
    Sep 13, 2003
    Skiatook, Okla. 74070
    Yeppir.... 275 is getting pretty tall for the front, though. I have a 79 Bird with 255/60s on the front and 275/60s on the back and it looks pretty good.
  7. The Champ
    The Champ Veteran Member
    5,179
    945
    Sep 14, 2000
    MN
    On the rear - 4.25" BS will most likely work for 275's.
    On the front - 4.25" BS on a 15x8" rim will most likely not work with 255's.
    As posted by GoldenOne - a 235/60/15 will work on the front. 245 - maybe - but I think that would be the limit.
  8. SlowJammin
    Nov 7, 2013
    Los Angeles, Ca
    Thanks for the response fellas. I'm going to buy 15x8 4.25 BS for the rear and 15x7 4.25 BS for the front. For tires the rear will be 255/60 and front 235/60. I think that will fit and look perfect.
  9. SlowJammin
    Nov 7, 2013
    Los Angeles, Ca
    Hey doc, those tires are tucked perfect!
  10. scot1074
    scot1074 Veteran Member
    360
    Jun 3, 2004
    Prospect Ct, USA
    295's fit. It's just what you want for the size.
